Old 02-25-2022, 06:51 PM   #1
Vortech
Vortech's Avatar
Steering column lower bearing
Lower bearing on my steering column is shot. Is this lower part that holds the bearing set 2 pieces or one? I ordered a lower bearing, thinking I just need to knock out warn out bearing race and install new bearing. But lower section race appears to be part of the lower section?
Vortech is offline   Reply With Quote
Old 02-25-2022, 07:13 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Steering column lower bearing
I haven't done one myself, but it looks to be possible to take the two pieces apart.
Here's some good pictures of one taken apart and rebuilt: https://lugnutz65chevystepside.weebl...n-rebuild.html
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-25-2022, 08:46 PM   #3
Vortech
Vortech's Avatar
this is perfect, I'll need to source some ball bearings, since I lost a few. thanks. I thought the piece with the red arrow was removable. Hopefully I did not damage it.
Old 02-25-2022, 11:18 PM   #4
cwcarpenter98
I think it is removable, which is why you can replace it with either a bronze bushing or another stock style bearing.
I haven't done one myself, but I'm sure there's someone out there who has
Christian Carpenter
Old 02-26-2022, 10:35 PM   #5
Bushman66
This bearing had failed on my 66 (prior owner) and the broken, hardened race cut nearly through the column. I replaced this bearing with the bronze bushing...works great, and the bronze will never damage the column... Think I picked it up at Classic parts, can't recall exactly.
Bushman66 is offline   Reply With Quote
Old 02-26-2022, 11:48 PM   #6
Vortech
Vortech's Avatar
Thanks, ordered the lowering bearing, will see if I can knock out the old race and install new one
