67 gmc tie rod issues
67 gmc rebuilding front end. Started in drivers side and got to the tie rod ends and it is hitting. Any ideas? Hopefully the pics show up
Justin 1970 Blazer in progress |
Re: 67 gmc tie rod issues
Can you install the lower control arm shaft backwards? I’m thinking that’s what I did.
![]() Join Date: Aug 2005
Your lower control arms do look too far forward.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
![]() Join Date: Dec 2013
This is how it lined up on my 67 C10 with 2 1/2 " drop spindles and power steering , Using MOOG parts . need some more pictures of what you have .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Post Whore
![]() Join Date: Feb 2016
It looks as if your centerlink is backwards compared to Grumpy's. It could just be the camera angles. See angles of the red lines below. There are numerous threads on which way to install the centerlink to help you verify if this is the problem.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Oct 2005
It looks like the center link is on wrong. Its also possible the steering gear is not lined up right. The 67 models came out with linkage type power steering & to put the later type gear on you need a conversion bracket kit.
George |
![]() Join Date: Dec 1999
just went and tried to take a picture of mine from the same angle. I'm guessing your centerlink is in wrong. It tucks up so close to the crossmember when done right, you would think it's wrong.
Thank you for your replies. The center link may well be the problem. However I will need a picture of what it should look like from the passenger side.
My issue is that it didn’t hit before I took it apart, and now it does and I didn’t mess with the center link. But after taking this think apart 5 times I’m ready to try something else!
