Old 03-25-2022, 04:26 PM   #1
Rjjr
Exhaust
Can anyone tell me what exhaust manifolds came stock on a 1972 K-10 with a 350 ? I purchased the center dump ram horn manifolds that exit straight down but when I look for a dual exhaust kit it looks like the pipes are bent for the manifolds that exit on a 45 degree angle.
Rjjr is offline   Reply With Quote
Old 03-25-2022, 04:33 PM   #2
bry593
Re: Exhaust
If I recall, my '71 ram horns do in fact kick back on the driver side, but are mostly vertical on the passenger.
Those aftermarket manifolds are just straight up and down. Which is but one of many reasons I avoided these. Instead, I filed flat the flange, heli-coiled the stud holes, and then blasted and hirsch painted my originals.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 03-25-2022, 04:38 PM   #3
tutone
tutone's Avatar
Re: Exhaust
I pulled this one off an internet search. It is a big block, but the small blocks were very similar. Pass side dumps at about a 45 degree angle and looks about like that one on the DS except for the heat riser damper, which by the way will probably be inoperable after 50 years. I prefer the ram horns myself. I will have a custom exhaust bent for mine, and that may not be an option you want to use.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 03-25-2022, 05:15 PM   #4
1967-C10
1967-C10's Avatar
Re: Exhaust
if you want oem exhaust to bolt up.
Use oem. manifolds.
1967-C10 is offline   Reply With Quote
Old 03-25-2022, 07:35 PM   #5
bluek5
bluek5's Avatar
Re: Exhaust
The 4x4’s are straight down the 2wd’s angle back.
bluek5 is offline   Reply With Quote
Old 03-25-2022, 08:07 PM   #6
truckster
truckster's Avatar
Re: Exhaust
Exactly right.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-25-2022, 08:27 PM   #7
stepsider
stepsider's Avatar
Re: Exhaust
I just these off my 72 c10 with a 350 motor. Hope it helps.
stepsider is offline   Reply With Quote
Old 03-25-2022, 08:56 PM   #8
truckster
truckster's Avatar
Re: Exhaust
But he has a K-10...
Old 03-25-2022, 11:05 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Exhaust
This is correct.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-25-2022, 11:22 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Exhaust
Assuming K10 is same as K20.... mine (72 K20) with a 350, both sides center dump straight down. Just as mentioned in posts above. OP, it seems the exhaust kit you're looking at is incorrect.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-26-2022, 10:55 AM   #11
72swbcamo
Active Member
Re: Exhaust
I Have 1972 K10. the exhaust manifolds are center dump that extend straight down, both sides. my truck has single exhaust that terminated on the driver's side just behind the rear fender. my truck is a short bed step side.
The driver's side header pipe drops straight down and bends to the rear along the frame rails. The passenger side drops down bends to the rear then crossed over behind the transmission pan and connects to the drive's side pipe. I have the original pipe. I have not been able to locate the header pipe. I had one made up by a muffler shop but the reproduction was not exact and needs to be modified. I will try to get a picture of the pipe and post it to this site.
72swbcamo is offline   Reply With Quote
Old 03-26-2022, 11:50 AM   #12
Grumpy old man
Grumpy old man's Avatar
Re: Exhaust
On my 67 2wd , I'm using the 2 1/2" center drop manifolds and they will require a custom exhaust . Using 2 1/2" pipe it will need to be bent like these pipes to clear everything . So you may have to do the same ? 4" radius bend using 2 1/2" pipe
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
