Old 04-10-2022, 01:51 PM   #1
19Suburban69
Lost pedal response
Installed 2006 6.0 out of escalade with 4L80 about a year ago. PSI harness, stock pedal/module assy and stock ECM. Yesterday on freeway lost pedal response. Engine running, but no power. Pulled over turned key off and found nothing obvious. Started up, all okay. Drove a mile or two and same thing. Pulled over waited about 30 seconds, restated and all okay. Fought it a few more times getting it home. Once it went into limp mode and only 30 mph. Where do I start? I don't have code reader. Would it show what's going on?
1955 Chevy, 2 dr post, my first car
1969 Chevy C20 Suburban, 6.0 LS w/4L80
2001 Silverado Z71, 5.3 extended cab
19Suburban69 is offline   Reply With Quote
Old 04-10-2022, 08:35 PM   #2
Ziegelsteinfaust
Re: Lost pedal response
Code reader would be the start.
On my E150 that's how the fuel pump showed up as the issue.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-11-2022, 06:49 AM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
Sounds like either the tac module or the pedal.
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
