04-11-2022, 03:05 PM | #1 |
laying low
Cabin temp regulation
03 Tahoe has new dash controller. Automatic climate controls. Now what causes the in cab temp to swing from warm to cool on its own? Is it the actuator itself going rogue or something else?
I have recalibrated the hvac actuators twice now.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 04-11-2022 at 06:16 PM. |
04-13-2022, 08:02 PM | #2 |
Moderator
Re: Cabin temp regulation
The digital heat/AC controller gets cabin temp from a sensor in the headliner over the driver's head. It has a little fan inside IIRC.
It looks kinda like a microphone grille. There's also a sun load sensor dead centre between the defrost vents on the dash that does double duty as a nighttime sensor to turn on the auto headlights. If both of those sensors are working properly and the ambient outside temp sensor is reporting the correct temp in your mirror then the HVAC controller may be flaking out on you. You should be able to get a look at the reported temperatures with an Snap On Verus, AUTEL Maxsys, or Tech2.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-13-2022 at 08:10 PM. |
04-13-2022, 11:08 PM | #3 |
laying low
I just recently replaced the control panel with a new one from O'Reillys, might be a Dorman. Everything works but when I commanded it to heat it began to warm then turned cooler over and over with the temp setting full hot. Since I've never changed the actuators on this old rig I assumed it might be one going bad. I just couldn't imagine it running back and forth temps own it's own.
I don't have either of those scan tools, just an Innova or something that only reads generic engine codes. When I get it back I will fiddle with it some more. I just had the A/C leak repaired too. That roof sensor has a little fan doesn't it? Seems like I used to hear it buzz when the radio was turned down. ?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
