Old 04-11-2022, 06:52 PM   #1
bglad420
bglad420's Avatar
Hood Hinge Options for Bagged/Slammed?
Curious what guys or gals are using for hood hinges aside from your standard $400+ cowl mount options? I need to trim my fenders for tire clearance and will be losing my stock hinges in the process. I know about Porterbuilt etc cowl mounts but was wondering if there was a more budget friendly option or an oem option that works well. I am curious if anyone has tried fox body Mustang cowl mounted hood hinges?
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 04-20-2022, 01:05 AM   #2
cab4word67
cab4word67's Avatar
Re: Hood Hinge Options for Bagged/Slammed?
You could do this?? And I kept my inners
cab4word67 is offline   Reply With Quote
Old 04-20-2022, 04:38 PM   #3
Mike Bradbury
Mike Bradbury's Avatar
I am not sure what you are replacing your wheel well with, Slosh Tubs or similar, but I made my own set of hinges from the stock set just put new custom billet hinges on the original brackets. Dressed them up pretty nicely and did not cost much to do. Of course there is a fair amount of fabrication in them but I saved about $700, and they open about 6" further than stock and about 12" more than PB cowl hinges.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
