04-18-2022, 11:09 PM | #1 |
wiring issue
Had to take out the ididit column from my truck for repairs. (Tilt lever came loose from column shaft. Repaired by ididit). After reinstalling everything my running lights come when I touch the brake pedal. Pretty sure we replaced everything as before taking apart. Any ideas.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
04-19-2022, 05:12 PM | #2 |
Re: wiring issue
I am ASSUMING that everything work fine before you took the column out. I am also going to assume that ididit assembled it correctly. So based on that I would check the connectors from the wire harness to the column. Make sure none got bent, shorting out, etc.
Keep us posted I am interested to see what the issue is.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
04-19-2022, 07:06 PM | #3 |
Re: wiring issue
Evidently when ididit reassembled the column they turned on emergency flashers. Reset flasher switch and all is good. Thankful it was as simple as that. Planning a 200 mile trip to Somerset Ky to cruise weekend Friday.
04-21-2022, 08:05 AM | #4 |
Re: wiring issue
LMAO, the simple things will always get you. Glad it was a sime oversight and not a wiring issue.
