1970 k-10 manual clutch linkage conversion to hydraulic clutch linkage?
Hello there, bought a 1970 k-10 awhile ago. Has a swapped 350 in it with a four speed manual transmission. The problem I am running into is the linkage rod is rubbing on the header and not giving my clutch the proper travel to disengage. Would it be worth converting to a hydraulic system?
Posted via Mobile Device |
Re: 1970 k-10 manual clutch linkage conversion to hydraulic clutch linkage?
It can be done if you’ve got a bucket of cash!
Post some pics of where the problem is. Could be an easy fix. Last edited by geezer#99; 04-21-2022 at 10:09 AM. |
All about them K’s
![]() Join Date: Jun 2014
It’s not that expensive if you source the right parts.
http://67-72chevytrucks.com/vboard/s...=662879&page=7 This is how I did it, scroll down that page a bit and you’ll see it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
