Where to get 12VDC wire for electric choke?
I just put a new 2 barrel carb. with electric choke on my 79 C10. It had a hot air choke on the old original carb. I have got to find me a switched wire for the choke. Where would be the best place to look for a wire under the hood. Without having to run a wire through the fire wall and find one inside cab.
![]() ![]() ![]() Join Date: Jan 2018
Re: Where to get 12VDC wire for electric choke?
I'm not sure about all the wiring specifics on a 79, but on my 63, I added an electric choke. I have it wired up with a relay so that the electric choke only functions when the engine is running. I used one of the wires off my alternator, but I'll have to go back and look as it's been a couple years since I did it. It has worked nicely for me
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Active Member
![]() Join Date: Jan 2017
I used the windshield wiper motor 12v supply for the electric choke on my 1978
Not on my truck but I ran a wire from the fuse block ignition plug .
Just here to tinker
![]() Join Date: Jun 2008
Any switched source should be fine except the wire going to the distributor.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Might see if there is a spare wire back where the oil sender normally sits, next to the distributor. On vehicles with electric choke, the choke wire often went though one side of the electric oil sender so the choke coil only got power when there was oil pressure. Might get lucky and the vehicle is already setup for electric even if it came OEM with a hot air version.
#7 | |
Hot in run and start, but not in accessory.
I would check the fuse box to see if the choke option was hooked up, some time the choke option is on the fuse panel is dead other time it is live on one side you can tap in there.** use the proper fuse size on a spade tap fused wire to the carb. ( if your lucky your truck was hooked up wire was run not used it wrapped in the loom. But if was hooked the wire fire wall was not run you just read above wiring on the engine wire plug connector seal it up pop in fuse in factory fuse holder (choke location) your golden.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Moderator
![]() Join Date: Oct 2008
You could use an oil pressure switch like the TBI systems have for the fuel pump power.
That way it only powers up when the engine is running.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#10 | |
The carbureted ones work the same way, according to the wiring diagram.
