Old 05-05-2022, 12:50 AM   #1
inkslingrrr
inkslingrrr's Avatar
Question Steering help
Hello friends, need help with a steering question … I'm trying to change It all over to Borgeson but seem to be running into a wall . I'm doing a 71 c10, got the top figured but out can't seem to get the right u-joint coming off the steering box… I really want to abandon the rag joint…any help would be greatly appreciated.
inkslingrrr is offline   Reply With Quote
Old 05-05-2022, 04:09 AM   #2
SIXTY9
Re: Steering help
Steel Double D U-Joint 1" DD x 13/16"-36 spline
Part Number : 153-015240
Telescoping Double "D" Steering Shaft 3/4 in.-DD x 1 in.DD x 26 in. Long
Part Number : 555-607102
Steel Double D U-Joint 3/4"-36 spline x 3/4" DD
Part Number : 153-013449
These are the part numbers that I used on my 69. These are JEGS part numbers. The power steering box was from a 75 Chevy truck.
SIXTY9 is offline   Reply With Quote
Old 05-05-2022, 12:29 PM   #3
inkslingrrr
Re: Steering help
Is the steering box the same from 75-71? The spline size is my issue
Old 05-05-2022, 01:14 PM   #4
SIXTY9
Re: Steering help
Measure your shaft coming out of the gear box. If measures 3/4 it should work. if not JEGS has different sizes.
