05-07-2022, 09:51 PM | #1 |
Driveline Vibration
C20 stock ride height, 4.10 31.65" high tires 7004r trans. I have a vibration that comes on at about 55 and blurs the rear view mirror. At about 70 the speed of the vibration is higher and not shaking the mirror. Also a droning is noticed.
2 piece drive shaft rebuilt and balanced by a local shop. Did not shop vibration. Installed the 7004r trans had driveshaft shortened and balanced no change New Tires, balanced and then rebalanced with a road force machine no help installed pinion shims to adjust angle as recommended by shop. slightly better. New brake drums no change Today, I put the axle on jack stands and ran to 55 still there. I removed wheels and drums, no change. reclocked the 2 piece drive shaft a couple of times no change. Then I left the rear part of the drive shaft off and smooth as can be. It is either in the rear driveshaft portion or the rear end. (dana 60 full floater) any ideas?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-07-2022, 10:32 PM | #2 |
Re: Driveline Vibration
When did it start? When the OD transmission was installed?
05-08-2022, 08:14 AM | #3 |
You made it sound like the transmission came after the vibration. My hunch says it's worn pinion bearing. You say shimming reduced it some. My mind went to the pinion bearing even before reading about the shimming. The droning also would support my hunch. The whole line is balanced now, so pinion bearing again
05-08-2022, 09:29 AM | #4 |
Before as far as I can remember. Previously I had a 2004r and before it TH350. It always has had a vibration, but it is worse now
05-08-2022, 09:31 AM | #5 | |
05-08-2022, 09:49 AM | #6 |
I agree. You have eliminated everything except for the rear end.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
05-08-2022, 11:07 AM | #7 |
I agree, it is time to inspect the differential.
Bearings can, and do, fail without going loose. It also could be the ring gear bearings which wouldn't show in a pinion inspection. I would pull the differential cover and look for evidence of a partial failure. It should be fairly obvious, with metal in the bottom, if it is indeed the Dana 60's bearings. BTW; You did an excellent job of eliminating the various vibration sources. Cheers. |
05-08-2022, 01:09 PM | #8 |
I think you guys might be right. I thought I was crazy but it seemed as if the vibration was less when cold just starting out and if I drove some distance 50 miles or so on the hwy it would be worse. Actually when thinking about it kinda makes sense. The diff oil is thicker when cold giving the bearings and gears more cushion. As it heats up the oil gets thinner having less cushion.
Hopefully, I'm not overthinking it. My plan is to take it in and have the diff rebuilt adding posi. I do all my own work, but have to concede on working on a diff as I don't really have the tools and parts source to tackle it.
05-09-2022, 08:59 PM | #9 |
Have you checked drive line angle?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-10-2022, 12:34 AM | #10 |
Yes and adjusted it in a little closer with a 2 degree shim.
05-10-2022, 12:39 AM | #11 |
A incorrect differential angle would not likely produce the symptoms mentioned.
05-10-2022, 10:11 AM | #12 |
that's what I found, didn't really change anything.
05-10-2022, 11:01 PM | #13 |
How is the condition of the driveshaft hanger bearing? If the rubber is worn it will cause a vibration.
05-11-2022, 09:54 AM | #14 |
Was rebuilt by the driveline shop.
05-11-2022, 11:43 AM | #15 |
Your symptoms sound similar to what we dealt with a few months ago.
Watch & really listen to this video. It's more than just pinion angle, but angles at both ends & overall angle of shaft itself too. https://www.youtube.com/watch?v=SH2VIoWOQ0E Hope this helps!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
05-17-2022, 05:02 PM | #16 |
Experiencing the same symptoms in my 72 C20. It has a 09' 4.8L with 4L60E trans and 3.73 rear end. Driveshaft is 1 piece and balanced several times.
I haven't worked on a rear end - I would expect that the gears would have to be reset after replacing the pinion bearings? |
05-17-2022, 09:45 PM | #17 |
Post Whore
I went through the bad vibe blues when I started driving my Burban. It had what I believed to be 106k miles at the time. Over several months I chased the vibrations.
New exhaust helped. A new 2 piece drive shaft with a billet carrier bearing and a sliding joint in the rear axle and corrected U-joint angles helped. Having the rear axle rebuilt with all new bearings and gears finally cured all of the vibrations. It's likely that any truck with excess of 100k miles will need similar attention. Once these trucks became old and had little resale value, maintenance like oil changes became unimportant. Good luck with your search and keep us posted on your findings.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-18-2022, 12:59 AM | #18 | |
I typically replace the bearings and reuse the same shims. Then I check the gear pattern before calling it good. The bearings are so close in dimensions, no matter the manufacture, it almost always works out. If you have to change the gear set it's a different ball game. The bad news is it takes a significant amount of tools to get the bearings off the pinion. Some experience helps. Getting the preload is another PITA. Typically few have a torque wrench that measures in inch pounds. 15 inch pounds it a typical value. My torque wrench maxes out at 30 inch pounds. It can be done other ways but it's not fun without the proper tools. Cheers. Last edited by Accelo; 05-18-2022 at 08:54 AM. |
05-18-2022, 10:37 AM | #19 | |
05-18-2022, 05:12 PM | #20 | |
05-18-2022, 07:48 PM | #21 |
Do it now and you will forget about the price soon. If you don't you will be kicking your own A** forever.
May save a little $ on the install as the old bearings will not have to be removed from the used carrier. A side benefit is the right rear tire will last longer. On the 3/4T there are at least two different differentials. Depending on the springs. You may want to check the style and pricing on the Differential you have. Unsure, but the Eaton could be spendy if you can find a posi carrier. Others will have to chime in on the feasibility. |
05-18-2022, 08:20 PM | #22 |
Hey Terry, FWIW, I had my 3.08s swapped to 3.42s and added posi when my 12-bolt was rebuilt. I like my setup with the 700R4 and 3.42 gears, although if you're on the interstate a lot I can see keeping the 3.08s. I think I'm pulling around 2000RPM at 65-70MPH, so I lost some top end, but the local driving is more fun.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
05-18-2022, 10:09 PM | #23 | |
05-18-2022, 10:11 PM | #24 | |
good advice. I have a Dana 60 full floater with 30 spline axles. Will have it all redone.
05-19-2022, 08:34 AM | #25 |
With a 700R4 a 4.1 is a monster stump puller gear. A 3.7 or even a 3.5 type ratio is still stout on the low end and will lower the revs at speed. TH350 and TH400 are both right at 2.5 first gear and of course direct in high. A 700R4 is 3.06 in first and .7 in OD. So effectively with a TH350 or TH400 you are 10.25:1 in first and 4.1:1 in high overall driveline ratio. With a 700R4 and 4.1 you are 12.6:1 in first and 2.87 in high. Same calculation for 3.7 rear gear 700R4 is 11.32:1 and 2.59:1. Same calculation for 3.5 rear gear 700R4 is 10.7:1 and 2.45:1. with a 3.5 and 700R4 you still have more first gear than the TH350/TH400 with 4.1 had and still drop your revs at speed about 40%. Just some thoughts.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
