05-10-2022, 04:00 PM | #1 |
wheel tire combo
I've been researching to find out if my stock height 71 Suburban will ride and turn with this combo, found a set of 5x5 17x9 black steel wheels with 255/60R17 tires, as it is currently sitting, not running and unable to to a dryfit
I need advice from the vast member pool. thanx |
05-25-2022, 05:14 PM | #2 |
Re: wheel tire combo
I'm guessing whatever deal this was has passed you by. I don't own one of these but I hop over here now and again just to see what's going on. you would need to give quite a bit more information for somebody to tell you if these wheels fit. Like at least manufacturer. If your truck is stock, then don't you have six lugs? In which case those wheels wouldn't fit, but I don't mean to state the obvious or insult you. But if your truck is still 6 lug then saying that you were going to convert it would be an important piece of information. Hope this helps for next time around. If I were you, I would read people's build threads and see what size of wheel and tire they are putting on their Suburban. Then you would have an idea of the range that would be open to you.
