05-16-2022, 05:17 PM | #1 |
Guidance preping for paint with new Mar-k bed
I purchased a new bed from Mar-k. It appears to be excellent quality and very straight visually. My question is about paint prep. Is it feasible to shoot it with Epoxy then go straight to high build polyester? Are these beds good enough to do this? I can do a skim coat of filler if needed, just trying to save some time. Thanks.
05-16-2022, 05:40 PM | #2 |
Re: Guidance preping for paint with new Mar-k bed
I can't speak about all paint companies, but for PPG you can't put poly primer over epoxy unless it has cured for a long time. I've seen people do it, then after paint the paint will "gas out" and it will look like the car has the measles.
PPG has a high build epoxy, VP2050, or CRE that you can go direct to metal and have epoxy qualities but it has the build of polyester.
Glenn 1951 3100, Area51 1955 BelAir, 4EVER17 1987 R10, Ethel Copper Hill Rod & Custom http://67-72chevytrucks.com/vboard/s...d.php?t=829856 |
05-16-2022, 06:06 PM | #3 | |
05-16-2022, 06:17 PM | #4 |
Oh ok. Maybe I just misread the question.
Here’s how I look at that. For the most part the outsides are pretty good and the majority of the sides are covered by the fenders. I suspect that if anything you may want to do the inside of the sides. To tell, wet the bed sides with a wax and grease remover and sight the length of them and see how straight they are.
05-16-2022, 06:24 PM | #5 |
Post Whore
I have a all mar-k bed here..based on what I see itll need epoxy, which means the surface needs roughed up..I'm gonna hit mine with 80g then spray epoxy..the epoxy will give me a good thickness to smooth while sanding ..but from what I've seen , the panels are in great shape..but as you know, packing ,handling , and shipping , might not have been a gentle ride..so there could be things that need fixed..
But . I'll epoxy, smooth it, fix what needs fixing, then epoxy again, smooth it, then high build , smooth again , followed by paint
05-16-2022, 06:45 PM | #6 | |
05-16-2022, 10:37 PM | #7 |
rn rdthefox i wouldn't go less than 240 to scuff it down then go high build block with 240 to noke it down and move to 320 and 400 for singel stage paint. at any point if you see its not going to get all the low spot re shoot win high build.forgot to mention to use guide coats between grit change. guide coat help to see low spot's. go to 600 for a base coat clear coat. just how i do it. when doing high build do at least 2 coats and wait for it to flash between coats about 20 minutes better to wait a bit more than to try and rush to put it on
05-16-2022, 11:42 PM | #8 |
yep, if it doesn't cure enough between coats then the first coats will offgas and create bubbles in the top coat....trust me. you can peel it off like saran wrap
05-17-2022, 03:06 AM | #9 |
Back in the early 80's some guys were saying that the spot welds showed up big time on Mar-K bed sides . That is the only gripe I have ever seen on them.
It's like anything you buy for these trucks, you may have to do a bit of work to get to the level of perfection you want.
05-17-2022, 07:12 AM | #10 |
Post Whore
the mar-k panels are electro-galvanized...make sure whatever you do its compatible
05-17-2022, 08:42 AM | #11 |
05-17-2022, 02:14 PM | #12 |
There is more info on this PFD that you are going to want when you assemble the bed but scroll down a ways and they cover painting the electro galvanized parts. https://www.mar-k.com/PDFs/Instructi...Wood-Floor.pdf
You probably want to save that PFD to the computer as I am pretty sure you will be going back to it a few times. Found with a Google search rather than hunting the website. The concept is sand the Zink but don't go through the Zink.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 05-17-2022 at 02:22 PM. |
05-17-2022, 09:07 PM | #13 |
I wouldn't use 80g anything on any body panel with e-coat or primer on it
Start with reading the PDF mr48 posted I'd likely scuff it with W&G remover and a scotchbrite
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-17-2022, 10:25 PM | #14 |
Post Whore
I'll be using spi primers on my stuff..so I'll go with what they say..
When I said 80g and epoxy , I was thinking more of my fenders, which arnt coated .. The mar-k stuff may not need epoxy..but if epoxy is to be used, it needs something aggressive to bite into
05-19-2022, 10:41 AM | #15 |
I am THRILLED with the quality of the Mar-k bed. Mine got an SPI epoxy primer, done deal.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-19-2022, 11:22 AM | #16 | |
05-28-2022, 09:36 PM | #17 |
It depends if you are going for a driver quality or show. For driver quality, you could get by with just epoxy. My Mar-K bed still needed filler on the opposite sides of the spot welds, and tops of the rails. The vertical stake pockets took A LOT of filler!
They were not flat enough for just epoxy. I started with 80 grit on the D/A. Shot with epoxy, then filler work. Then Featherfill G2. Sealed with epoxy, then base/clear. Polyester primer over epoxy would depend on the product you're using. I use SPI epoxy, and it is OK to put poly primer over IF you wait at least 48 hours.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
06-02-2022, 04:48 PM | #18 | |
Thanks for all the comments. |
