05-18-2022, 04:49 PM | #1 |
DoubleWall HardTop Installation Help
just purchased a 70 blazer cst and a hardtop. The top was purchased separately and did not come with any mounting brackets or hardware so I was wondering what is needed to mount the DoubleWall top to my blazer
05-18-2022, 05:50 PM | #2 |
Re: DoubleWall HardTop Installation Help
How nice is the blazer? Are you worried about scratching it while installing the top?
Are you trying to do this just to get it home? And if so how far will it need to travel? One of my blazers was shipped 1500 miles with just the front bolts and the rear bolts holding the top on and none of the bolts that went up from underneath the bedside. I usually take a couple of 2 x 6 boards long enough that they extend past the bedsides about a foot. One person on the end of each board and you can place the top on the bedside with no concerns about it falling off and damaging the vehicle. You can then lift the front of the top and remove the front board. And then the rear of the top and remove the rear board. The bolts that go up from the bottom of the bedside into your double wall top are 5/16 x 18 thread. I would run a thread chaser into all of the top holes before trying any of this. At the front of the blazer the two corner bolts go through the visor mounting bracket and into the top from the bottom. It is also I believe 5/16 x 18 but it’s at least a couple of inches long. Does your top have the two brackets that hang down at the back of the top and bolt to the bedside? And do you have the two little brackets with the three holes in them from mounting the top to the windshield frame?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
05-18-2022, 06:05 PM | #3 | |
05-18-2022, 08:15 PM | #4 |
Without knowing much about your top. I would make sure your double wall is ready to be mounted. You may know the double top bolts go from under the bedside into the top. On my last double top half of the inner nuts were stripped inside the shell and took a little extra work.
Just for the fun of it |
05-18-2022, 09:59 PM | #5 |
Carpe manana
There are two brackets that affix the top front to the windshield frame, two bolts (one ea) at the visor brackets, the bolts 7D2N mentions, and two brackets that affix the top to the bedside just rearward from the tailgate. Do you have existing threads/holes for the front and rear brackets and are the visor bracket present?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 05-18-2022 at 10:43 PM. Reason: Added |
05-18-2022, 10:40 PM | #6 |
Interesting. I always thought mine was double walled based on how heavy it was lol. But my bolts come in from to the top trim and screw down toward the ground into the bed side .
05-19-2022, 11:46 AM | #7 | |
05-19-2022, 11:49 AM | #8 |
The tops aren't that much different in weight. Actually, someday I want to weight both to know the difference but haven't yet.
05-19-2022, 07:59 PM | #9 |
Anyone have a picture of the rear brackets?
05-19-2022, 09:00 PM | #10 |
05-19-2022, 09:18 PM | #11 |
Thank you!
Didn’t know this was a thing so I’m missing part of that bracket I guess? |
11-29-2022, 12:21 PM | #12 |
That banana shaped bracket must have been added in that latter years ? My 69 never had it either
