06-08-2022, 01:39 PM | #1 |
Good lower Rht front fender patch!
Read several post about having to modify the rht front fender patch. I picked one up from AMD and it was very close fit! I drilled out the spot weld on the very front portion and just had to move it slightly to line up.
06-08-2022, 03:41 PM | #2 |
Re: Good lower Rht front fender patch!
Nice work there!
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
06-09-2022, 09:40 PM | #3 |
Looks good! And very similar to mine, except I had to cut mine apart even more than just the spot welds to get it to fit!
My 67: http://67-72chevytrucks.com/vboard/s...d.php?t=784468 |
06-10-2022, 09:32 AM | #4 |
I had to do the same as what appears in your image. Cut it down the middle. Fit the rear section up so the body line & wheel open features align. Fit the front section up so it fits best. The make a filler piece for the gap between the F & R sections.
06-11-2022, 06:02 PM | #5 |
Glad you got a good patch panel. Mine was a challenge to get it to fit right. Had to cut it both vertically and horizontally to make it fit right.
Nice job and looks good.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
