Old 06-18-2022, 06:39 PM   #1
cericd
cericd's Avatar
Heat Stove Screw Size
Anyone know the correct size of the heat stove screws? I'm missing the two that hold connect the stove pipe to the heat stove, also missing one of the top heat stove screws. Are the ones that connect the pipe to the stove the same size as the others along the top of the stove?
Also, do they reproduce the two heat stove pieces or will I need to restore my originals? I know the pipe should be black but what finish would the stove have had? I assume most finishes will burn off due to the proximity to the exhaust manifold.
Pics of what I'm talking about.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-18-2022, 11:36 PM   #2
cericd
cericd's Avatar
Re: Heat Stove Screw Size
Found a thread that answers my "original finish" question https://www.67-72chevytrucks.com/vbo...d.php?t=670464. Still not sure about the screw sizes.
Chris
Old 06-19-2022, 10:12 AM   #3
DaHos
DaHos's Avatar
#10 sheetmetal screw with 5/16 hex
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 06-19-2022, 02:00 PM   #4
cericd
cericd's Avatar
Hex head? My originals that are left are pan head Phillips.
Chris
Old 06-19-2022, 02:21 PM   #5
54blackhornet
54blackhornet's Avatar
I have the original set up on my 71 C20. The screws are sheet metal with hex heads.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-19-2022, 02:52 PM   #6
cericd
cericd's Avatar
Interesting, wonder if they made a change from 70 to 71. I feel like the "patina" looks pretty uniform from screw head to stove metal to lower nut & bolt. I guess I really just need to figure out if all the holes are the same size. Also, I can't find a repop of the heat stove so I guess it's not reproduced.
Chris
Old 06-20-2022, 01:06 PM   #7
54blackhornet
I am referring to the two used to secure the pipe up to air cleaner.
71 C-20
07 Magnum RT AWD
Old 06-20-2022, 01:45 PM   #8
cericd
cericd's Avatar
Oh, I wasn't sure if they were all the same or if the two for the pipe were different. Thanks for confirming.
Chris
Old 06-20-2022, 02:22 PM   #9
cericd
cericd's Avatar
While doing some more searching through the forum I ran across a thread by IronCanine on the subject of heat stoves. davischevy posted a couple pics of his 56,000 mi C10 and it appears that all screws across the top are indeed hex head. It appears however that the two for the pipe have larger heads than the others. Looks like my two Phillips screws are OLD replacements.
Here are davischevy's pics.
Chris
Old 06-20-2022, 02:55 PM   #10
IronCanine
I'm trying....
IronCanine's Avatar
I believe the hex head sheet metal screws are correct for both the tin to tin connection and the tube to tin connection. I don't think there is a specific call out in the assembly manual, but I'll check tonight as well as post some pics of originals I have at home.
Most of the time those tins came off and never went back on...but if they did, it wouldn't surprise me if a lost screw got replaced or if a hole was wallowed out and a larger screw stepped in.
Also, hardware could be variable amongst plants or time periods...so it is conceivable that other hardware may be seen. Every one of these that felt honest and original to me had hexes.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 06-20-2022, 03:18 PM   #11
Joesjunk
Joesjunk's Avatar
I would completely agree
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 06-20-2022, 10:35 PM   #12
davischevy
davischevy's Avatar
I just looked at a 72 that I built over 30 years ago and it has the 5/16 hex head screw in the pipe. The K10 I am building now has 5/16 hex head in the pipe.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-20-2022, 11:03 PM   #13
IronCanine
I'm trying....
IronCanine's Avatar
Parts manual calls for #8-18. All the ones I have are just that. Some have an M makers mark. 1/4" socket fits em all. I don't doubt that the tube screws could have been #10s from the factory. It makes sense, those are the screws really under a load. Also, the ones most likely to get wallowed out and get upsized IMO.
Also, Larry has previously made a point about what he has seen finish-wise on low mileage examples he's owned...and I've recently seen it myself. It appears the outer half of the heat stove tins was painted black and the inner half was unpainted. You can see it in the pic Chris posted of Larry's truck and in the rough original example shown below.
Old 06-20-2022, 11:06 PM   #14
IronCanine
I'm trying....
IronCanine's Avatar
Old 06-20-2022, 11:39 PM   #15
cericd
cericd's Avatar
Thanks for all the great info and pics guys. What would you think the original finish on the fasteners would've been, black oxide? Any recommendation on a source for some new replacements? M maker's mark not necessary.
Chris
