Old 06-23-2022, 11:30 AM   #1
stepsider
stepsider's Avatar
Question Door check repair
Can the door check be removed to repaired without removing the hinge ??
Can it be repaired while in the truck ??
I got the parts from Classic parts
All help or info appreciated.
stepsider is offline   Reply With Quote
Old 06-23-2022, 12:09 PM   #2
cj847
cj847's Avatar
Re: Door check repair
Short answer is yes.
The only issues I had were the roll pins were rusted solid. I used a LONG (like 12" or longer) drill bit (in order to clear the door frame etc with my drill). I replaced them with a different size. It is better if you can get the stock ones out as I think they are tapered vs straight.
You pull the stuff out from inside the door and replace the pads. I had to connect them to the A pillar and use the door to get them fully seated. I greased them and worked them back and forth a few times to break them in.
cj847 is offline   Reply With Quote
Old 06-24-2022, 08:22 PM   #3
stepsider
stepsider's Avatar
Red face Re: Door check repair
I finally got it done. Had a hard tine pushing out the roll pin. Had to grind a chisel to fit the tool pin hole & a bigger hammer. Soaked the hole with oil and started pounding. Not that hard of a job jus the roll pin removeal. Also replace the door handle assembly. Two birds one stone
