07-06-2022, 07:29 PM | #1 |
Widest wheel on stock a arms
Hey guys, I'm just curious what is the widest wheel/tire combo you can get on the stock a arms. I'm wanting to go with a 20x12 with 295/30/zr20. I would rather not switch a arms right now if possible, I just cupped the stocks for the airbags
1968 C10 SWB, mild 355,5/7 drop, budget frame off, piecing it back together! Last edited by kcstreetracer; 07-06-2022 at 07:40 PM. |
07-07-2022, 10:51 AM | #2 | |
Re: Widest wheel on stock a arms
You can set the back-spacing/offset so they only have minimal interference concern w/the arms but they're going to extend well past the body. Try to tuck them within the body & they'll make contact w/the a-arm or frame @ some point in the turning radius.
07-12-2022, 05:24 PM | #3 |
I fit 19x12's on a 66 if that helps any. I had to trim the control rib near the ball joint to get some turning radius back though. Post #324 in the thread
http://67-72chevytrucks.com/vboard/s...74#post6586374 |
