07-11-2022, 10:10 PM | #1 |
Belleview winch install
Dug one of my Belleviews out that I've been hoarding and a period correct Warn bumper..was on the fence about the turn signals but I believe I'll use the Warn guards and factory lenses..
I'll add more pics with all the cables and turn signals on |
07-11-2022, 10:53 PM | #2 |
Re: Belleview winch install
That looks killer!
07-20-2022, 07:22 AM | #3 |
Turn signals mounted...winch cable next
07-20-2022, 09:15 PM | #4 |
If you run a set of Dapper Lighting OE7 headlights, you can get them in LED with OE style glass and an integral turn signal bulb that is unnoticeable when its not blinking.
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 |
07-20-2022, 10:02 PM | #5 |
I'll have to check that out..thanks for the info
07-20-2022, 10:12 PM | #6 |
Here's a few pics....you can see the tiny LED signal bulb....they came with the clear bulb installed, but they also come with amber replacements, depending on how you want to use them. Installed, they look almost factory, and they light they throw out is excellent, and the cut off is the best I've seen from any aftermarket LED. Not cheap, but in this case, you get what you pay for.
07-21-2022, 06:11 AM | #7 |
Where is the best place to buy these?
07-21-2022, 08:04 AM | #8 |
