08-08-2022, 11:57 PM | #1 |
Moderator
Best way to adapt 73/87 spindles to a 68?
Ive located an elusive set of fabtech 4.5 lift spindles for a 73/87 truck and Im going to use them on my 68. I know I can just swap the upper and lower ball joints out in my a-arms, my question is can I use a 73/87 center link also so I dont have to use conversion sleeves and monkey around with adapting 68 tie rods to 73/87 outer tie rod ends? Will the 73/87 center link work in my 68, that way I can just use 73/87 inner/outer tie rods for simplicity? Thanks!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-09-2022, 12:23 AM | #2 |
67-72 parts collector,
Re: Best way to adapt 73/87 spindles to a 68?
Yes. I’ve don’t the conversion using a 71-72 centerlink and tie rods with 71-72 spindles.
Should be the same for 73-87 spindles and 73-87 centerlink and 73-87 tie rods.
08-09-2022, 12:27 AM | #3 |
Moderator
Cool thanks. What about the idler arm and pitman arm? I looked up the part numbers on those and they are both different.
08-09-2022, 12:29 AM | #4 |
I used 71-72 parts.
Seriously the conversion tie rods sleeves is the easiest way. Run your 68 outer tie rods at the INNER location. Then use 73-87 outer tie rods with your lift spindles. Thats what I would do.
08-09-2022, 12:33 AM | #5 |
Moderator
Thanks, that does sound easier. Do you know who still sells them? The thread sizes are different also, so I assume one end of the sleeve is one size and the other end is the other size?
08-09-2022, 12:45 AM | #6 | |
One end 5/8” LH thread the other end is 11/16” RH thread. (That’s why you have to move your 68 outer tie rod in. ) CPP makes them. I would use the ones from AZ ProPerformance. Edelbrock and QA1 use to sell them also. www.PerformanceOnline is another source. Finding them in stock might be an issue.
08-09-2022, 12:52 AM | #7 |
Moderator
Thanks Keith, going this route is a done deal. The 73-87 brake hoses are much longer too, hopefully long enough for the increased lift.
08-09-2022, 10:35 AM | #8 |
BlahBlahBlah
Lift spindles? What are the plans for your 68?
08-09-2022, 11:20 AM | #9 |
Its a Truck Thing......
The center link changed around 83 for the Idler Arm. Make sure you pay attention. The stud went smaller into the link. 82 and down used the same Idler for many years.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
08-10-2022, 12:41 AM | #10 |
Moderator
Im going to lift the front with spindles and the rear with coil spacers. Goal is to lift/level it for some 33 tires. Its been done with 88/98 lift spindles, but you cannot use 15 steelies and thats something I want to retain. In addition to that it requires purchasing more parts than using 73/87 stuff. The calipers, rotors, pads, bearings, etc that I already have on my 68 from a previous disc conversion will all bolt right over onto 73/87 spindles.
08-10-2022, 11:15 AM | #11 |
BlahBlahBlah
I think thats going to look very cool. There are a few trucks here on the board that are two wheel drive but up a little so they can fit bigger tires, very burly looking.
08-11-2022, 01:05 AM | #12 |
Moderator
Yeah I looked for a K truck for a while with no luck. Looked for a K chassis to swap under my 68
no luck. I really dont need 4wd, but I like a lifted longbed with bigger tires, and I use it like a truck so this is the way to go for me.
Performance online is local to me. I stopped by their showroom after work today and picked these up
08-11-2022, 08:14 PM | #13 |
I used the same POL adapters.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
08-17-2022, 02:20 PM | #14 |
BlahBlahBlah
I keep coming back to this thread ... Do you have a timeline on this or is it a long term kind of thing?
08-19-2022, 12:36 AM | #15 |
Moderator
No real timeline other than I do want to get it done As soon as the spindles get here I’m going to get them cleaned/painted and ready to install. According to the seller they should be pulled and shipped out next week. I’ve been getting parts together so that I can get it done in a day whenever that day happens to be. I’m off work in a few weeks so I should be able to set aside some time to do it then.
08-20-2022, 06:04 PM | #16 |
I used the parts below on my 69 C10 with 1986 spindles. Center link was from a 71-72 C20, but I think a 73-87 C10 center link is the same part. (73-87 C10s were much beefier than earlier years.)
Be aware that there were two different model spindles for 73-87 C10s (at least starting in the mid-80s). One was for 1" thick rotors, the other was for 1.250". The inner wheel bearings and calipers are also different. Pads are the same.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
08-20-2022, 08:45 PM | #17 | |
Center links changed from 83-87. The Idler is not a K6096T. Idler is K6247T from 83-87. 82 and down uses the K6096T. Smitty
08-21-2022, 09:18 AM | #18 |
Smitty, thanks for the corrections. When I made that chart many years ago, I ASSumed that 73-87 parts were the same. For future reference I'll modify the chart to have three model year columns instead of two.
However, bottom line is I used the parts in red on my 69 C10 with 86 standard duty spindles. BTW, I think the "T" suffix is simply the latest version with a powdered metal gusher bearing. Another note: When I first did the conversion, I used adapter sleeves from Golden State Pickup Parts (remember them?), I always thought it was kludgy and might confuse a future owner or shop, so was glad to find the proper center link. To the OP: You will probably have to hit some junkyards to find a center link, but the adapters will work in the meantime.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-21-2022 at 09:28 AM. |
08-21-2022, 03:50 PM | #19 |
Moderator
Spindles came in earlier than expected. Blasted and ready for paint, just need to decide on color. Took one down to POL to check fitment for brake dust shields. The counter guy told me they only fit OEM spindles and did not fit aftermarket or lowered spindles, they even have the disclaimer on the box These spindles were tapped and drilled so he humored me and pulled one out of the box for a test fit. They fit perfectly with no issues He was probably more impressed than I was He did say that he had never seen lift spindles for a square body before.
08-21-2022, 06:33 PM | #20 | |
No issue, I have no idea why they changed it, I think the newer one is weaker than the 6096. I also suspected they used the same center links on squares until I mounted this last crossmember under my 68. Had a 6096 ready to install when I found out the differences in them. I think I may still have a GSP catalog in the cabinet, I'll have to dig through the piles and check... Smitty
04-21-2023, 02:25 PM | #21 | |
One of the First
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
04-28-2023, 09:25 PM | #22 |
Moderator
Just finished installing them this week, along with 1.5 spacers in the rear. Truck now stands level and high enough to clear 33s. Im very happy with how it sits.
04-29-2023, 12:36 AM | #23 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Nice, I like it! I put 3/4 ton springs rear and 1" risers on the front lower springs. I had 15 x 31's on it...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 04-29-2023 at 01:20 AM. |
