View Poll Results: Poll: Do you have a functioning parking brake on your airbagged truck?
Yes, I kept the factory setup. 5 55.56%
Yes, but it's a custom setup. 2 22.22%
No, I don't have a parking brake. 2 22.22%
Voters: 9. You may not vote on this poll
Old 08-24-2022, 12:30 PM   #1
evan
evan's Avatar
Poll: Do you run a parking brake on your airbagged truck?
If you're running airbags, do you still have a functioning parking brake?
Evan B.
evan is offline   Reply With Quote
Old 08-24-2022, 03:24 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Poll: Do you run a parking brake on your airbagged truck?
I voted, "Yes, But I have a custom setup" however, I don't have a bagged truck. Lowered 4 front and 6 rear(with notch), with the exhaust up in the frame much like a bagged truck.
Using the factory parts was not going to cut it. Would have interfered with the exhaust and the 4L80E trans crossmember...
Jason Banks is offline   Reply With Quote
Old 08-24-2022, 03:31 PM   #3
evan
evan's Avatar
Thanks. I just realize now the wording in the poll options might need clarification. What I meant by "custom setup" is referring to the parking brake cable routing/parts.
Evan B.
Old 08-24-2022, 06:40 PM   #4
68 C10 Driver
I don't have a bagged truck, but as part of my restoration I plan on installing an E-Stop set-up.
68 C10 Driver is offline   Reply With Quote
Old 08-24-2022, 10:21 PM   #5
Jason Banks
Are you also interested in what we did? i don't have any pictures, but could take some...
Old 08-24-2022, 11:24 PM   #6
Big Kev-O
Big Kev-O's Avatar
Yes, please share the details. I need to buy new headers and move the exhaust above the frame rails. Few pics would be great.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 08-25-2022, 10:17 AM   #7
evan
evan's Avatar
Yes, that would be great!
Evan B.
Old 08-25-2022, 03:34 PM   #8
typerr
I'm not on bags, more like a 5/7 static drop but I wanted to get rid of the ugly parking brake cable in the engine bay. I added a pulley to the parking brake assembly in the cab so I could point the cable straight down, drilled a hole behind the inner fender to hide the cable and now run a Lokar cable that terminates at my transmission crossmember. My exhaust is not tucked into the frame so this might not work for everyone and I'm not completely done but it was an easy way to clean up the ugly cable but keep the parking brake. Also much cheaper than an e-stopp.
typerr is offline   Reply With Quote
Old 08-25-2022, 05:12 PM   #9
Jason Banks
For the cable I used - Dorman 21119 Brake Cable Repair Kit With Cable Stop - So, I could cut it a custom length.
For the pulleys I used:
https://www.mcmaster.com/catalog/128/1660 for the roller and https://www.mcmaster.com/catalog/128/3704 for the pin through the roller.
I made the metal pieces that hold the rollers that are all bolted to my Holley transmission crossmember.
I looked into using some of the Lokar parts, but never really figured out what I needed.
I wanted to try to keep the cable up inside the frame but settled for this where the cable is all barely below the frame. I have not figured out yet, if the cable hits the bottom of the trailing arm crossmember, but I figured it it does I figure I'll put some delrin pads on the crossmember where it hits.
Comments on my welding are welcome
Old 08-25-2022, 09:40 PM   #10
Big Kev-O
Big Kev-O's Avatar
Wow Jason, that is one clean undercarriage! Thanks for the info & part numbers.
Old 08-25-2022, 09:55 PM   #11
kev2809
low n' slo
kev2809's Avatar
damn that is clean!
to the OP... why are you considering no e brake?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-26-2022, 09:27 AM   #12
SCOTI
SCOTI's Avatar
I have bags on my Squarebody dually w/a 4-bar set-up vs. leafs w/the factory e-brake set-up. It can plant the frame rails on the concrete & required no mods.
My old '68swb had bags on the the rear truck-arm set-up w/a functional stock e-brake set-up. No mods required for it as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-26-2022, 12:55 PM   #13
evan
evan's Avatar
Thanks, that looks great. I'd be scared to hear what your budget was for v-band clamps! lol
Originally Posted by kev2809 View Post
damn that is clean!
I've had the truck for a few years now and the e-brake has never worked. Right now it just clangs and rattles on the 3" exhaust. To get ride of the racket I see two main options: A) rebuild my exhaust and fix the e-brake, or B) remove the non-functioning e-brake cables. I know the "right" thing to do but I was kind of hoping to hear a bunch of people say they got rid of theirs and don't regret it.
Evan B.
Old 08-26-2022, 01:40 PM   #14
SCOTI
SCOTI's Avatar
Most won't regret it until a loss of hydraulics. That's usually when they're appreciated the most (by your family, my family, & your insurance company).
https://www.youtube.com/watch?v=5oO226PgSkg
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2022, 01:57 PM   #15
kev2809
low n' slo
kev2809's Avatar
^^^ this is what convinced me just to rebuild mine (havent done it yet). i was in the same thought process though, its bagged and cant move with no air. didnt even think of the event of a brake failure
-_--_--_ _________
Old 08-26-2022, 04:22 PM   #16
tjc
tjc's Avatar
I have bags in rear only and installed an electric emergency brake
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 08-26-2022, 04:32 PM   #17
kev2809
low n' slo
kev2809's Avatar
do you have pictures of this set up?
-_--_--_ _________
Old 08-27-2022, 08:24 AM   #18
tjc
tjc's Avatar
no picture yet, my truck will be finished in about 2 weeks.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 09-02-2022, 03:58 PM   #19
typerr
Here is a photo of my brake release out of the truck on my bench. The pulley was purchased from McMaster Carr. The cable and little bracket are Lokar. This will work with any shaved firewall. I basically modified the stock part to do exactly what the aftermarket Lokar brake lever does. I also replaced the mounting studs with nutcerts so I can just have allen screws at the firewall.
Old 09-02-2022, 10:02 PM   #20
kev2809
low n' slo
kev2809's Avatar
that looks nice
-_--_--_ _________
