09-03-2022, 05:12 PM | #1 |
Rear Parking Brake Cable for 4” lift?
My parking brake cable started to fray and was causing binding. Order a new set off Brothers. Of course they are short and not for a 4x4. (Their listing didn’t specify)
Can anyone point me towards stock cables I can use? I’m just looking for the rear portion going from the drum to the connector that sits in the middle of the truck. I see some go with Lokar but I’m not looking to replace the whole system. Ideas? |
09-04-2022, 08:07 AM | #2 |
Re: Rear Parking Brake Cable for 4” lift?
I have an extra set of black Lokars I'm not using, can be cut down, don't know if they would work for your application since I went a different route
I can measure them, but I don't know how a factory connector looks at the center link, if you have a pic, I could confirm if these would work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-04-2022, 08:50 AM | #3 |
I have a 14 bolt and it matters as to the connection at your brakes. I went to the junk yard and found a set off of a FURD van were long enough and had the right connections. 4 inch lift of course.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-04-2022, 01:43 PM | #4 | |
09-05-2022, 10:25 AM | #5 |
Having a hard time loading pics, but cable ends at connector are blank, brake arm has a swaged ball, LMK
09-05-2022, 10:28 AM | #6 |
09-17-2022, 07:28 PM | #7 |
Just to wrap up this thread. Found the cables at In-Line tube. Correct length 48”.
09-20-2022, 11:46 AM | #8 |
