09-04-2022, 02:46 PM | #1 |
Front & rear Bilstein Shocks
Hi All I'm wondering what's the right sizes or part number of Bilstein Shocks for a JIMMY 1972 4WD , Thanks
MY Facebook ( saad_alhajri ) on Instagram
09-08-2022, 02:58 AM | #2 |
Re: Front & rear Bilstein Shocks
When I last looked a few years ago Bilstein only produced a replacement for the front. There were some threads about modifying the rear shock mount and using a different shock, but I don't remember exactly which one or what was done.
I'm running rancho 9000's right now which are better than the extremely cheap KYB shocks that were way too soft. It still rides like ****, but I think a lot of that comes down to the sagging leaf springs and poly bushings. I'm waiting on new springs from Alcan, so I'm hoping everything works out. If I didn't already have $400 into the rancho's I would probably go with bilstein's.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
09-08-2022, 04:30 AM | #3 |
Hello,
Thank you for contacting Bilstein of America. Unfortunately we do not make any shock absorbers for your vehicle at this time. This is the company's response. But I think the front fits perfectly, but the rear I don't know
09-08-2022, 08:06 PM | #4 |
I think monroe shocks have both for it i have the part numbers if you want
09-09-2022, 07:44 AM | #5 |
In my humble opinion there is no better than Bilstein Shocks . about experience
09-09-2022, 09:31 AM | #6 |
Contact shockwarehouse .
https://www.shockwarehouse.com/site/bilstein_5125.cfm Below is a chart for the 5125 Series that are sold by size, not application. Due to the variances of different modifications to a vehicle, or lift-suspension kits, it is your responsability to confirm that the shocks you purchase are dimensionally correct.
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-14-2022, 09:14 AM | #7 |
Will see if I can find the info, but later model shocks fit with trimming the inner metal core. Have Bilsteins on mine.
