Convert bench seat from spring to full foam type.
I am thinking about converting the seat in my ‘70 c10 to full foam. From pictures I have seen it looks like the frames are the same for both types but the springs are different. The foam type is basically flat across the base while the spring type is raise several inches.I want to cut out the existing springs and build a base out of something like a grid spring attached to the frame with coil springs. Has anyone tried this type of conversion? Do you think it would work?
Posted via Mobile Device |
#2 | |
This photo shows a Tahoe seat. This is kind of what I am thinking.
Re: Convert bench seat from spring to full foam type.
The photo above shows a Tahoe seat, this is kind of what I am going for. While filling in the cut outs at the ends with either more foam or leaving the existing springs on the ends.
![]() Join Date: Dec 2013
The flex-O-Lator springs come in different widths and can be found here . Along with the tension springs .
https://www.albrightssupply.com/springs The seat frames of the 70 model are close , You will need to use a barrier type material between the foam and springs to protect the foam from getting cut thru . Rather than using an aftermarket foam you may be better served by just buying a block of foam and using a cheap turkey carving knife to cut and shape the foam .https://www.amazon.com/Proctor-Silex...53328878&psc=1 But yes given some time and creative effort it can be done . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Oct 2014
Re: This photo shows a Tahoe seat. This is kind of what I am thinking.
This grid and spring kit is for a 81-87 bench seat. It’s going to take a lot of work, because the size of the frame is different from the earlier seat frames to this seat frame. And the grid & springs were made specifically for this frame, 1981-1987. Plus the foam that is used is a different size.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
I should have been more clear. The photo is just an illustration of the general idea. I would buy a grid spring that is larger than needed and cut to size.
#7 | |
Thanks for the link Grumpy. It looks like the outside edge of the flex-o-later springs is rope of some kind. Do you know if this is correct? I didn’t see a description on the website. Any opinion on which would be better between that and the zigzag springs?
Yes, I’m aware of that. I have gotten the Flex-O-Laters grids also. But the generic photo he used is a kit from USA1 Industries, specifically the correct length & width for the 81-87 bench seat. They already have the correct size springs. So in this particular case, there’s no quessing on the size needed.
![]() Join Date: Dec 2009
I have a seat I bought at a swap meet that has that type of system on it.
It is a 68-72 seat frame.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#11 | |
The edges of the Flex-O-Lator are pressed cardboard wrapped wire . Using zig zag springs would be a lot more work and you would have to tie them together to work as a system similar to the Flex-O-Lator , I have a couple seat frames in the garage I'll take a look today and give you the path I would take to build a custom seat .
#13 | |
#14 | |
Here is the 67-68 seat frame. The only one I have ever had. And it’s a full foam seat.
