09-07-2022, 10:50 AM | #1 |
Larger fuel tank capacity
Forgive me if this has been covered already but I searched and couldn't find much. Obviously these trucks don't get good mileage in any capacity, but, has anybody swapped in a larger tank for better fuel range so you can make it farther between fill ups? I want to get the tank out of the cab anyway so I'm looking for the largest tank I can fit under the bed.
I saw someone once using a 70s f body tank and they mounted it so it filled behind the license plate which would be a nice setup. Those tanks are 21 gallons which would give me 5 additional gallons. I'll go this route if it's the biggest thing I can find, but I'd love to get something 28-30 gallons if it's possible. Space may be an issue. |
09-07-2022, 10:55 AM | #2 |
Re: Larger fuel tank capacity
I plan on putting in a 31 gallon square-body suburban tank in my 70 (LWB). They also make one that is 40ish gallons. The standard square-body Blazer/Suburban tank is 25 gallons if yours is lower a good bit. You will have to make a custom filler for the tank. Either behind taillights, sidemaker or inside bed corner.
Here is one of the videos I was referencing. https://www.youtube.com/watch?v=2e-J_0_djjE It is for 4x4, but should work on the 2WD model Here is another from an older board member https://67-72chevytrucks.com/vboard/...d.php?t=218898 The attachment is another one I save from somewhere many years ago.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 09-07-2022 at 11:22 AM. |
09-07-2022, 12:14 PM | #3 |
Location: Herculaneum MO (20 minutes south of St. Louis
The in cab tank is 21 gallons, so you don't gain anything with that fbody tank.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
09-07-2022, 02:22 PM | #4 |
09-07-2022, 03:18 PM | #5 |
09-07-2022, 04:15 PM | #6 |
20' Daredevil (Ret)
Same as my K20. One time years ago on a cross-country trip it took just over 50 gallons to fill the tanks.
