09-11-2022, 10:59 AM | #1 |
We’re the Highlander Bench seat plaid pattern misaligned from the factory?
Were the Highlander plaid patterns on the truck bench seats misaligned from the factory? You can see how poorly aligned the driver’s side seat pattern is on this blue seat. In most pictures I’ve seen It’s hard to tell because in most pictures the seat is at an angle.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 09-11-2022 at 11:22 AM. |
09-11-2022, 11:52 AM | #2 |
Re: We’re the Highlander Bench seat plaid pattern misaligned from the factory?
Not sure about the alignment, but that seat this beautiful looking!
09-11-2022, 12:28 PM | #3 |
Who Changed This?
One would like to think that the stripes would be aligned, but this doesn't surprise me.
09-11-2022, 12:43 PM | #4 |
I can see a slight misalignment but that is extreme.
09-11-2022, 01:40 PM | #5 |
I have no idea if the patterns could come offset like that from the factory. It would drive me nuts though. MAYBE if both sides had the same offset. The good thing is that you have to really look for it at an angle and that's how you would see it 99.9% of the time.
I'd challenge the suppler to straighten it out, if it were me.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-11-2022, 01:41 PM | #6 |
I would say most if not all original patterened fabric are designed to be alligned when cut to be sewn , The material comes 57 inches wide ,Some 60 " so that even if it is to be used on bucket seats the pattern will match on both seats , Misaligned material on seats is usually upholster error or their just too lazy to make it match or it's just a cheap cover and quality control doesn't matter . Your new Chevy /Ford/ dodge cars and trucks that came with a leather interior ,The only real leather on the seat is the face that touches your body when your sitting in it ,the sides /back and bottom surrounds are all color/grain matched vinyl . it's all about saving every dollar for the manufactor . True 100% leather seats are very expensive
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-11-2022, 02:07 PM | #7 |
There was an old post about this and yes they were misaligned. Or i guess the fabric wasnt centered per seat. I think the thread was about how gmc used same plaid but turned 90 degrees on some 72s
09-11-2022, 03:29 PM | #8 |
I'd like to apply some common sense to this and support mrtoni's comment above me.
In order for the seat and back's material to match, each and every seat would have not only had to been assembled together, most likely by the same person, but the covers raw materials would have had to been sewn together on the spot as a matched and measured set. I believe this is what it means to be "tailored". That is an insane amount of work and effort for a cheap old workhorse truck build by GM for pennies. Would it be asking too much for a $7k Cadillac? Maybe not; but for a pickup truck....too much. These so-called "luxury" options that made these trucks more snazzy were nothing more than added plastic and chrome aesthetics; not custom hand built trucks. |
09-11-2022, 03:43 PM | #9 |
The vast majority from the factory were centered - or at least were pretty darn close. It wasn't rocket science or extra work as long as the centers of a vertical dark panels were centered in the vinyl opening for the seat back and the seat bottom (i.e. one didn't have to take all the extra care of aligning back and bottom, as long as centered in the opening, the rest would work out). Having said that, it's even less rocket science when it comes to the aftermarket seat covers - for the prices these things are these days, they should be centered, aligned, and come with a can of turtle wax. I would absolutely send them back, the driver's side seat bottom was clearly mis-stitched.
09-11-2022, 04:29 PM | #10 |
I am sure there was a quality control guy who - every once in a while - just wanted to go home.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-11-2022, 04:41 PM | #11 |
Yes
09-11-2022, 06:27 PM | #12 |
To me these seem not centered and original upholstery. Centering would create wasted material
09-11-2022, 06:34 PM | #13 |
Who Changed This?
I don't know what GM does now, but in those days they tracked costs to the 1/10th of a cent. Seems like they'd get a production run of the proper width material for the plaid inserts, and only have to cut the length. Then again, I was a designer of a device that was so small on part that the only way to get it put together was to use Kevlar "tow"- unwoven string, like used for protective vests. Had to buy a whole spool. Needed about 20 feet (so as to have enough to hold onto and tie it up) but a spool has about 5 miles of thread on it.
09-11-2022, 07:17 PM | #14 |
I thought that was common never seen them centered
09-11-2022, 07:35 PM | #15 | |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-12-2022, 06:40 AM | #16 | |
The pattern wasn't centered but the top and bottom were aligned or at least very close. It is obvious the pattern is intended to line up. The seat cover this thread was started for is a reject.
09-12-2022, 08:18 AM | #17 |
It's not the centering of the fabric in relation to the vinyl seams . It's the fabric to fabric pttern seat back to seat bottom that should line up .
09-12-2022, 09:04 AM | #18 |
Exactly! The patterns should line up, most definitely. I have seen some bad ones before, but this one is one of the worst! Lordy
09-12-2022, 09:13 AM | #19 |
Granted, this isn’t plaid, but it’s still a pattern. Everything should straight, symmetrical and line up together, from top to bottom.
09-12-2022, 01:38 PM | #20 |
Here is an original, definitely not lined up!
1972 C10 SWB 383 M22 1972 K20 454 1970 K5 1985 M1008 1986 M1008 2020 2500HD Duramax |
09-12-2022, 03:26 PM | #21 |
70+ ( Old Skool Club )
Went through my pic collection and found some original tired Highlander seat pics and patterns are offset. The seat on the garage floor is the original from my Hghlander and u can see the pattern isnt aligned. Had my buckets done with SMS Upholsterya few years ago and tld the installer I wanted the pattern to match on both seats and he delivered. He took the liberty of stitching down the black seams saying it will kep the material from sliding around when your sitting on it.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-12-2022, 03:31 PM | #22 |
Carpe manana
For K5s the bucket seat upholstery was centered and reproducible from vehicle to vehicle with the back and bottom cushion patterns aligned but not the rear seat, which was random. I'd like to see more examples but I believe the pickup seats were random and not centered.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-12-2022, 05:30 PM | #23 |
Post Whore
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-13-2022, 09:51 PM | #24 |
My SMS seat covers are pretty close to being aligned, at least when sitting on the hood of my 69 Camaro. I did not even know this was a thing until I read this thread but I am happy with them.
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) Last edited by 67RS/SSx2; 09-14-2022 at 09:39 PM. Reason: auto correct errors |
09-13-2022, 10:38 PM | #25 |
Carpe manana
OEM rear Blazer seats. Worse than the metal siding on my garage
