Always on the hunt...
![]() Join Date: Sep 2006
F/S OE GM 4wd AC Vacuum Storage Canister & Mounting Bracket Setups
We have three OE GM 4x4 K/model vacuum storage ball-tank-can-reservoir and bracket setups w/mounting screws available, these
were only found on the 4wd models with air conditioning and were mounted on the side of the evaporator core housing. The three storage tanks have been tested to hold vacuum and all have functioning one way check valves, add $13. for shipment in the CONUS. If interested, funds can be sent via paypal, venmo, check or money order, if using paypal option buyer covers fee's. Thanks, Mel ![]() #1/OE 4wd vac tank & mounting bracket assy. w/plastic tank, two setups pictured on left. $75. ea. ***Qty. 2 Sold/Shipped*** #2/OE 4wd vac tank & mounting bracket assy. w/early style metal tank pulled off a 70 blazer, pictured right. $100. ***Sold/Shipped*** .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... Last edited by Classic Bowties; 12-19-2022 at 07:59 PM. Reason: Availability update |
Re: F/S OE GM 4wd AC Vacuum Storage Canister & Mounting Bracket Setups
Last two pics...
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
![]() Join Date: Jun 2006
Hi Mel,
I will take both #1 assembly’s with plastic tanks |
Okay you got them, will combine shipping on both setups and send them via USPS priority med box for $16.10. Per your sent message, we do not have any 4wd exhaust manifolds pulled at this time. Thanks, Mel ![]()
Hey Mike, both of the #1/4wd AC vacuum tank & bracket setups have been shipped off, your package went out via USPS priority on Mon. 09/12 and the expected delivery day is this Thu. 09/15. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
![]() Also, here are a couple pics of the added single 72 saddle LH/drivers side male belt and retractor cover for your K/5 project. .
#7 | |
Option #2/4x4 vac tank and bracket setup available yet...
Active Member
![]() Join Date: Mar 2016
Will you do $75.00 for #2 vac tank if so I take
No we cannot accept that on the #2 67-70 K metal vac tank setup, if not in need of an early style tank setup we may have another later style plastic vac tank setup to pull and test. If the tank checks out the cost would be $75., same as the other two #1 setups that previously sold. Lmk, Mel
Active Member
Ok I will take it for the $100.00 nice talk to you
Okay the #2 setup is yours, the total and payment info for sending of funds via paypal has been forwarded on Sun. 09/18, please confirm your full shipping address and we'll get the part ready for shipment. Thanks, Mel
#13 |
The early style metal #2/4wd AC vac tank & mounting bracket setup is headed your way, the package went out via USPS retail ground on Mon. 09/19 and your expected delivery day is this Sat. 09/24. Thanks again for your order, let me know if we can help with any other 67-72 parts needs. Mel
