09-15-2022, 03:20 PM | #1 |
Stepside with 10in wide wheels in the rear
Ran into a little issue, Truck is hitting the inside of the tires now when we sat the bed back on to the frame. Im thinking some 1/4in spacers in the back to push the wheel out just a little. Thoughts? Any other fixes? Truck is a 68
To clarify, Not the outside of the bed, where the fender lip is, but the inside of the bed is where its rubbing. Thanks |
09-15-2022, 03:38 PM | #2 | |
Re: Stepside with 10in wide wheels in the rear
The next problem will appear at curbs, approaches and high speed corners that twist the frame and body. |
09-15-2022, 04:35 PM | #3 |
8 or 9 inch rims will fit better.
09-15-2022, 04:38 PM | #4 |
09-16-2022, 10:13 PM | #5 |
Original rear axle in your truck? I have 275 55 17 on 17x9 with 5” back space (zero offset) on my ‘69 short step, but to make that combo work I run a wider 71-72 5 lug rear axle. You could source a ‘70 axle if you wanted to keep 6 lug, it’s the same width as the 71-72.
09-16-2022, 10:30 PM | #6 | |
Running the same combo all around has a lot of advantages. While it's mandatory on a 4X4, it's just plain handy on a two wheel drive.
09-19-2022, 12:02 PM | #7 |
Went with a little wider rear wheel and tire combo... Have had the wheels since May, so I doubt I can send them back now. I think I can make it work with the spacers... I hope. If not I guess I will have to eat the cost and order a couple of new wheels
