Old 09-15-2022, 07:48 PM   #1
ricurt69
ball joint separator
On a 72 C10 I'm installing CPP lowered spindles. All the ball joints came apart with carful use of a pickle fork and a little hammer work ...except for the passenger side lower. Also tried a screw type separator that is useless on the lower joints wider surface. After lubing, a lot of hammering, air chisel etc it will not budge. I think the fork which is 5/8" thick bottoms on the joint and does not spread enough to pop the joint. I've already ripped the boot. Anyone make a ticker fork, or do the Lisle stepped forks work?
ricurt69 is offline   Reply With Quote
Old 09-15-2022, 07:50 PM   #2
ricurt69
Re: ball joint separator
By the way the front end was all rebuilt stripped and painted about 5 yrs ago and is not corroded.
Old 09-15-2022, 08:17 PM   #3
kwmech
With the upper arm still attached--but loose--loosen the lower nut, but leave about 5-6 threads holding it together, in other words room for the taper to jump loose somewhat. Let the suspension hang so you're using the front spring to help. Jack stand under frame. Shock the side of the spindle where the taper is with a BFH. That is all I've ever done without too much of a problem. The lower castle nut will prevent the assy from coming apart. Hope that make sense
kwmech is online now   Reply With Quote
Old 09-15-2022, 09:21 PM   #4
RustyPile
RustyPile's Avatar
One of these:
https://www.northerntool.com/shop/to...8883_200658883
in one of these:
https://www.bing.com/search?q=pneuma...ANAB01&PC=LCTS
Loosen the nut as mentioned by kwmech and hit the area of the spindle surrounding the tapered hole.. About 3 blows from the hammer and the joint will separate.
RustyPile is offline   Reply With Quote
Old 09-16-2022, 06:42 AM   #5
ricurt69
You guys just recounted the way I've done it. It's also difficult to get a real good swing with the hammer when the suspension is together and the truck is sitting on jack stands without hitting something else.
Old 09-16-2022, 08:05 AM   #6
Jason Banks
Jason Banks's Avatar
Try 2 pickle forks...Harbor Freight...
Jason Banks is offline   Reply With Quote
Old 09-16-2022, 08:08 AM   #7
Jason Banks
You could also try heating the spindle....its going to take a long time though. I usually use a propane torch so it's not really hot.... I just prop it up so the flame is where I need it and let it sit...
Old 09-16-2022, 09:55 AM   #8
Accelo
Accelo's Avatar
I have the luxury of owning a short hydraulic ram. Loosen both nuts but leave them on the studs. Insert ram, between the two joints, it pops one loose and then the other. It's really fast and easy. But not necessarily cheap.
Cheers
Accelo is offline   Reply With Quote
Old 09-16-2022, 10:05 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of threads that show simple home made tools.
http://67-72chevytrucks.com/vboard/s...d.php?t=624464
http://67-72chevytrucks.com/vboard/s...d.php?t=645497
Post #6 in second thread. Also check out post #10. You might give one of them a try.... (don't forget the safety glasses)
Post back to this thread if you try them and one of them works.
LockDoc
Leon
Old 09-16-2022, 10:24 AM   #10
A1971Blazer
A1971Blazer's Avatar
Don't laugh...
I bought this $20.00 tool from HF and hadn't used it until I did the disc swap on my 68...also used a little heat from a propane torch
tightened the tool down really tight the smacked the knuckle with BFH....popped right off...quite loudly I might add....
Name:  Screenshot (462)_InPixio.jpg
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-16-2022, 10:29 AM   #11
kwmech
With the caliper off and the spindle turned, I have no problem hitting the area with a 4lb ball peen hammer while laying on the ground
Old 09-16-2022, 10:49 AM   #12
michael bustamante
michael bustamante's Avatar
thisiis how i do it as well with a 2 pound sledge
1967custom
michael bustamante is offline   Reply With Quote
Old 09-16-2022, 10:56 AM   #13
Sheepdip
Sheepdip's Avatar
I worked my way thru school at a shop that did tires, battery's, alignments, front end rebuilds etc. The guy that rebuilt the front ends had pickle forks that went into an air chisel. Sometimes it took a little heat but they always seemed to come apart.
Sheepdip is offline   Reply With Quote
Old 09-16-2022, 07:28 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I spent two days trying to break one loose with a Pickle fork and when I found you could smack the spindle, it popped out on the second smack.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-16-2022, 10:58 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Air hammer to the spindle.
Never liked pickle forks tears up to much stuff.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 09-17-2022, 10:14 PM   #16
rockyrivermark
Put some heat on it. Then smack the knuckle best you can with a 2 lb hammer.
She’ll drop out.
rockyrivermark is offline   Reply With Quote
Old 09-18-2022, 08:47 AM   #17
jgrote
jgrote's Avatar
At this point, the OP is replacing the spindle and the ball joint. Go with heat. The amount of heat will be determined by the part coming out. It can't be stuck if it's liquid!
jgrote is offline   Reply With Quote
Old 09-18-2022, 05:13 PM   #18
RichardJ
I don't really care for the hammer method as most guys use. If a spreader or pickle fork doesn't work, I use a hammer, but only in conjunction a bucking hammer or bucking bar on the back side.
I use the largest hammer head or chunk of iron I can fit on the back side of the knuckle. The mass behind the knuckle keeps everything from moving and increases the shock of the hammer I'm striking against the front.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
