09-16-2022, 06:54 PM | #1 |
Removing trim question
Before I created this, I did a search for how to remove the Cab and Lower moulding, without breaking anything, but couldn’t find anything pertinent
As far as the cab moulding goes: Do the little plastic clips slide sideways to unlock from the stud? On the Lower Body Moulding: Is there a way to unlatch the mounting clips without destroying them? Thanks in advance |
09-16-2022, 09:25 PM | #2 |
Re: Removing trim question
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-17-2022, 07:27 AM | #3 |
This video is just what I was looking for, thanks
09-17-2022, 08:14 AM | #4 |
On the cab paint divider trim ,You can use a plastic trim tool to pop the 2 clips on the outside end behind the door and then carefully slide the trim out , When installing that same trim you set the top edge of the trim on the new clips and with a glancing blow with the palm of your hand snapping the trim into place , You can't slide the trim back in place without taking the chance of scratching the paint . , if your saving the trim to reuse after paint consider polishing it while it's still in place .
https://www.amazon.com/Tresalto-Auto...-1-spons&psc=1 https://67-72chevytrucks.com/vboard/...d.php?t=765868
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-17-2022, 09:10 PM | #5 |
Dually noted and thanks for the knowledge
