09-25-2022, 08:34 AM | #1 |
Shifter lever “Wobble”
My gift over seems too easy to pull back (out of the detent) before shifting gears, like the detent spring doesn’t have enough pressure to give a firm feel.
I have a tilt column from a 72 Blazer that I bought a long time ago on eBay. When I installed the column, I had to put the lever back on. It could be that I didn’t put the sprin in correctly, or that it does have the right spring. I don’t know. Is there a source out there for this little detent spring that I speak of? And, is there a secret to installing said spring, so that it’ll work correctly? Thanks in advance |
09-25-2022, 05:18 PM | #2 |
Re: Shifter lever “Wobble”
Any help?
09-26-2022, 12:11 AM | #3 |
Okay, I know there’s a member that rebuilds tilt columns, so if someone could tell me, I. Kuldip PM him for some insight.
09-26-2022, 12:36 AM | #4 |
Kind of only go in one way. Maybe lever is worn out. Classic Parts has replacements. Get the van lever if you have a smaller wheel. I have their van lever on my OEM tilt.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-26-2022, 11:58 AM | #5 |
Post Whore
Can you clarify what the problem is? I'm afraid I just didn't understand your post.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-26-2022, 12:41 PM | #6 |
The following thread indicates that the spring is still available from GM:
http://67-72chevytrucks.com/vboard/s...d.php?t=627718 There are a number of them for sale on eBay. |
09-26-2022, 01:34 PM | #7 | |
66 GMC Suburban Custom 66 Chevy K10 Suburban |
09-26-2022, 09:27 PM | #8 | |
I think you understand my issue. The lever spring doesn’t seem to have enough pressure to push it back into the detent. You could very well be right about the collar being loose|(which it is) and the issue it causes. I am going to contact 70shortfleet, to see if he can talk me through it. Thanks a bunch |
09-26-2022, 09:39 PM | #9 |
Good luck! keep us posted if possible, others will benefit from your experience with this.
09-27-2022, 11:34 PM | #10 |
