10-16-2022, 07:54 PM | #1 |
Bed tool box door
Does anyone know how to remove the tool box door handle?
10-16-2022, 08:46 PM | #2 |
Re: Bed tool box door
I believe you may have to split the skins to get it out .
10-16-2022, 08:48 PM | #3 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-16-2022, 08:56 PM | #4 |
Thanks, I was thinking the same. I have a rusted out door that I’m replacing so I will post a solution when I get it done. I’m thinking of drilling a hole and just putting a plug in it so I can rust proof the inside at the same time.
10-19-2022, 07:06 PM | #5 |
Active Member
Does any company make replacement doors?..I may have to re-skin mine if I cant find one
10-20-2022, 12:51 PM | #6 |
I looked and could not find a RE-pop door but our local hot Rod shop found one for me that was in great shape. I had to drill two holes in the back to remove the handle as the rod is put together before the skin is put on as was mentioned. I drilled two 1.25 inch holes that will take rubber plugs and give me room to remove and replace the rod.
Big shoutout to “The Hot Rod Corner” in Eugene Oregon. |
10-20-2022, 07:24 PM | #7 |
Active Member
Sound like time for some metal work then for me...Thanks
