Old 10-17-2022, 11:06 PM   #1
skidoo
Tci street fighter tranny 700r4
I have a 383 in a c10 2wd. Just installed a 700r4 tranny. When driving it when it shifts from 1st to 2nd gear i get wheel chirp. Is this normal with this type of trans?
skidoo is offline   Reply With Quote
Old 10-17-2022, 11:10 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Tci street fighter tranny 700r4
Strikes me as a performance trans characteristic...firm. I've seen where the upshift took over a second, which to me meant clutches were getting toasted. Ask TCI what it should shift like. I personally like a chirp (at a minimum) on upshift. When I took the shell of my truck, with the stock 400 trans, it spun the tire going into second. It's a feature, not a bug. YMMV
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-18-2022, 12:46 PM   #3
Accelo
Accelo's Avatar
You didn't mention the throttle setting when the tires bark.
At full throttle I would consider this normal for a performance transmission.
Especially, with the light weight on the rears, in a truck application.
At part throttle it is nothing but annoying.
You might consider changing out the servo for a less aggressive one if it's at part throttle.
Be cautious as any changes could void your warranty.
Cheers
Accelo is offline   Reply With Quote
Old 10-19-2022, 10:44 AM   #4
ls1nova71
ls1nova71's Avatar
I had a TCI street fighter 700r4 in my Nova years ago. It was the same, couldn't keep it from chirping the tires on the 1-2 shift. Even at low speeds. Was fun when there's a cop beside you... I got to where I could just let out of the throttle a bit just before it shifted and it wouldn't do it. It eventually broke it's self, and I had a trans shop fix it but it didn't last, so I had to get another trans to have rebuilt, they said the case was bad. Never had any troubles out of that one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-20-2022, 09:05 AM   #5
Bigdav160
Bigdav160's Avatar
I bet they blocked the 1-2 accumulator circuit on purpose.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-20-2022, 10:38 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Taking the spring out of the accumulator is an option in the Trans-Go kit, iirc. It's been 40+ years since I put one of them in a vehicle.
~Steven
Simi Valley, CA
Old 10-20-2022, 02:31 PM   #7
HO455
Post Whore
HO455's Avatar
I'd look at this thread. It seems to be a wealth of knowledge on 700R4s.
http://67-72chevytrucks.com/vboard/s...d.php?t=634121
Good luck and let us know what you find.
RIP Bob Parks.
