Old 10-28-2022, 07:15 AM   #1
pound41
Installing Rain gutter trim
Any kind of gasket or sealer attach to the gutter trim before it goes on the truck. Thanks
pound41 is offline   Reply With Quote
Old 10-30-2022, 09:31 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Installing Rain gutter trim
3m clear two-way tape had at factory. 3m gray foam two- way tape I think it 1/16 or 1/8 thick, But the screw holes need to be sealed maybe try this screw threads just before screwing down. GM they use to use bee wax stuff. It did two things lube the screws & helped try seal the screw hole threads. I have tried silicone dabs on the screw threads not the best for paint back in the day. I never thought about this. http://www.amazon.com/Pipe-Joint-Com.../dp/B000KKVWL6
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
