Old 11-01-2022, 08:59 PM   #1
May70
May70's Avatar
Axle Swap
Well I finally made it through my axle swap. 14 bolt with discs and parking brake. Posi/LS with 4.11 gears from my 6.0 Ls/4l80 donor.
My plasma cutter broke, I got somewhat ripped off, had numerous trips back and forth to the rear end guy but hey, its in. I used captainfab's brackets and widened them since the newer 14 bolts are wider in diameter.
I put a video up on YouTube to show people how I did it all as usual. Can be referenced for any trailing arm GM truck that a swap is desired.
https://www.youtube.com/watch?v=cvS9...omRestorations
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 11-01-2022, 09:59 PM   #2
yuccales
yuccales's Avatar
Re: Axle Swap
Great video.
yuccales is offline   Reply With Quote
Old 11-02-2022, 02:24 AM   #3
jumpsoffrock
Re: Axle Swap
Thank you for posting this video, I may be going down this road myself. Same 14bolt and ratio I'd need too.
Do you know what year 14 bolts are a direct swap in with these 67-72 trucks?
jumpsoffrock is offline   Reply With Quote
Old 11-02-2022, 10:47 AM   #4
May70
May70's Avatar
Re: Axle Swap
What do you mean by direct swap? I wouldn't consider this a direct swap
Old 11-02-2022, 11:35 AM   #5
jumpsoffrock
Re: Axle Swap
I seem to remember reading that the 14 bolts from the square body era bolt in place of an H052/H072. If that's true, I wonder what year rear end that ceases to be true.
Old 11-02-2022, 11:50 AM   #6
May70
May70's Avatar
Re: Axle Swap
I assume your question about a direct bolt in is in regards to the leaf spring trucks?
I don't know the answer to that since I have not dealt with the leaf springs.
