11-02-2022, 10:43 AM | #1 |
E-Stopp Emergency Brake
Has anyone on this site installed, or is planning to install the E-Stopp Brake system on their C10? I plan on doing that on my '68, then use the parking brake handle as a hood release handle.
I want to keep the parking brake handle because it is something that nowadays is such a rarely seen thing. It really gives the interior a unique look. Thanks in advance. |
11-02-2022, 10:25 PM | #2 |
Re: E-Stopp Emergency Brake
Hi 68C10, I installed one on mine. Pretty easy setup, I have a rear disc conversion with the Buick riviera calipers and universal rear cable kit.
What questions did you have? Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
11-03-2022, 11:49 AM | #3 |
I was mostly curious as to if there were any issues you had to deal with in order to get the E-Stopp to mount/interface with the brake system. Did you use the existing parking brake set-up? I see you mention using universal cables...
I also want this as a security measure as well, but as we all know, anything security wise can be bypassed if you know the vehicles well enough. Did you go with the push button, or key set-up? Thanks for responding, I look forward to your reply. Cheers- |
11-03-2022, 11:58 AM | #4 |
Pics are kind of big so I’ll do each separately. Push button mounted in dash above original pull handle. Just made wiring easier for me.
11-03-2022, 12:01 PM | #5 |
Used the template that comes with the E stopp to locate and weld bolts to my frame. Just long enough to run what I needed to behind the body of the brake actuator.
11-03-2022, 12:03 PM | #6 |
From the E stopp setup to the universal cable block is pretty easy. I left plenty of cable for adjustability and to see if there was any play in the system. I do plan on trimming up a little still.
11-03-2022, 12:06 PM | #7 |
From the cable block attached to the E stopp I anchored the universal system to the driver side rear frame support. Larger self tapping screws for now but plenty of room to use bolts if needed.
Pretty much it from there. Just run the park brake cables to each caliper and adjust tension. I have tested in the garage but my truck isn’t running yet. Still finishing up the Holley terminator X wiring to the LS swap. Should be rolling in a week or two. Hope any of this helped. Roger
11-03-2022, 12:14 PM | #8 |
Forgot the security part of your question. I suppose anyone could still just slip under the truck and cut any one of the cables. Same as factory cables. The advantage I saw in this system was more of eliminating the handle pull lever or the foot lever. I have a 67 small window cab on my 71 so getting rid of the handle helped me clean up that foot well.
11-03-2022, 02:23 PM | #9 |
72again4x4, that is a very clean install. I like how that is laid out. I am planning on hiding the button on my truck, so no one knows it is there. Once the E-Stopp is installed, I am going to repurpose the parking brake handle to use at the interior hood release. I like the look of the handle, just emphasizes the vintage look of the truck. Here is what the interior is shaping up to look like on my truck, still a work in progress. I am going to repaint the steering wheel to match the interior.
11-03-2022, 04:04 PM | #10 |
Post Whore
Have you actually tried to stop the truck with new setup?
Is it an effective emergency brake?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-03-2022, 05:30 PM | #11 |
HO455,
No emergency stop test yet. Still finishing up the engine wiring. Won’t be on the road until next week or two.
11-03-2022, 06:00 PM | #12 |
Post Whore
Please post your findings once your back up and running. I'm interested in the results.
Thanks in advance.
11-03-2022, 06:40 PM | #13 |
Will do.
11-03-2022, 07:24 PM | #14 |
Very interested in this also.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
11-20-2022, 10:51 PM | #15 |
I will be beginning the frame restoration in a couple weeks, hopefully I will be making the E-Stopp purchase in January and get that installed/set-up on the frame.
11-21-2022, 12:23 AM | #16 |
Not being familiar with the actual operation of the E-Stop...what happens if your battery goes dead?
11-21-2022, 10:23 AM | #17 |
I would assume it will remain engaged if the brake was set before the battery died...not sure, great question. I will have to ask the company that. When I get a reply I will post the answer.
11-21-2022, 10:26 AM | #18 |
So here is the answer they had in their FAQ section:
Q: What happens if my battery dies for other reasons while the brake is engaged? A: The unit remains engaged until it receives power again. So if the battery does die, and you need to move the truck before getting a new battery, you can always use jumper cables or a battery charger to supply power to disengage the E-Stopp. |
11-21-2022, 11:55 AM | #19 | |
Thank You for the reply. |
11-21-2022, 02:07 PM | #20 |
When I've had to use the E-Brake/Hand Brake as the only brake, after having lost the main brakes, it was necessary to feather the pressure to slow down and eventually stop ( thus preventing lockup of the rear wheels ). With the E-Stopp, is it possible to do this or is it full on/off only? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-21-2022, 05:47 PM | #21 |
I’m going to install this on my k5. I believe the system has a mechanical stop once engaged if I remember right.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
11-21-2022, 06:37 PM | #22 | |
I am just looking for this as a parking brake/anti-theft feature. |
07-18-2023, 10:54 AM | #23 |
Junior Member
72again or 68C10Driver (or anyone else that has it), any updates on your experience with the e-stopp?
I'm considering this for my 67 since my parking brake is currently disassembled. This looks like a clean way to reroute cables and remove the interior handle. |
07-18-2023, 11:35 AM | #24 |
Coldrider,
My experience is still limited. I only installed it for the parking brake aspect. To another point made in this thread, it has a screw gear that slowly engages the brakes and probably wouldn’t amount to much in an emergency situation. I’m still working on my truck so haven’t tried it in that way yet. Holds tight when parked in my driveway and doesn’t budge. For the power out or dead battery, it gives an annoying and constant tone letting you know the battery power is getting low. As for disengaging, you do have to jump or charge your battery to get it to work again.
