Old 11-03-2022, 09:18 AM   #1
Northbound
Build sheet codes 'n stuff
I'm trying to figure out what the "D89 paint stripe" originally looked like, any thoughts" Any other comments on the sheet are also welcome.
Northbound is offline   Reply With Quote
Old 11-03-2022, 09:45 AM   #2
mr.mud1
mr.mud1's Avatar
Re: Build sheet codes 'n stuff
i see lower body moldings on your spid but not upper,my Fremont built 72 Cheyenne Super says "BX2 Lower Moldings" and "B85 Upper Body Moldings" no mention of a paint stripe.i'm not a 100% sure but i think you'll find your truck had the lower moldings,as it says,no upper moldings and i think,thin double lined painted on pinstripes where the upper molding would be,if the truck had them.
mr.mud1 is offline   Reply With Quote
Old 11-03-2022, 10:04 AM   #3
fun in dirt
fun in dirt's Avatar
Here's another guy's that has that top stripe & bottom trim. It shows his SPID too with D89 listed.
http://67-72chevytrucks.com/vboard/s...ory+pin+stripe
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 11-03-2022, 10:28 AM   #4
mr.mud1
mr.mud1's Avatar
that's what i was thinking.perfect.
Old 11-03-2022, 11:00 AM   #5
Northbound
Looks like a double stripe that comes to a point at the front, ... white. It has a white roof, and I suppose that it part of the 542 paint code? I do have the lower body side molding and it must have been a solid color because the glove box sticker say "med olive" only. On the build sheet it has the "-b-cc " color code, which I assume must match up to the medium olive color.
Old 11-03-2022, 11:08 AM   #6
mr.mud1
mr.mud1's Avatar
i had a blue and white 72 truck years ago but no pictures of it,had blue bottom up to the white roof.lower wide moldings and the painted on white pinstripes.it seems to me,and "fun in dirt" has already put a link for another truck with the painted upper pinstripes,you'll see a double stripe,coming to a point on the front fender,and i think i remember,the lower part of the pinstripe being a little heavier than the upper stripe?
Old 11-06-2022, 10:41 AM   #7
sloGMC
Active Member
Do you have this truck? What fender badge does it have?
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
