11-06-2022, 07:25 PM | #1 |
What do you do for tie down points on your flatbed?
I put an underbody tool box on my 88 C30 today, and I had to mount it flush under the bed for ground clearance. I used to use wire hook straps sort of jammed under the edge of the bed rail, but that was kind of sketchy and I had one pop off once. With the toolbox now I couldn't use that strap type even if I wanted to. See picture below.
I have a ton of snap hook straps and stake pocket D rings I use with my trailer, and I really like those since they don't come off even if the strap becomes loose. I'm thinking about adding stake pockets and rub rails like I have on the trailer, but that is pretty heavy and kind of a pain. I'd like to keep the top surface of the bed flat for any oversized cargo, so welding d rings to the top surface of the bed frame is out. What would you do to safely attach tie down straps to the truck in this situation?
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread 1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread 1979 Corvette - 350 T5 1977 Jimmy - 350, TH400, NP203 1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck Scratch built 16' flatbed trailer - thread Last edited by 79vette; 11-07-2022 at 12:34 AM. |
11-06-2022, 07:54 PM | #2 |
Post Whore
Re: What do you do for tie down points on your flatbed?
i have these on my truck bed and trailers...and i also have the rub rail stake pockets on my trailers
11-06-2022, 08:18 PM | #3 |
I don’t have a flatbed but I have used etrack in trailers and other situations that I needed tie down locations.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-06-2022, 08:24 PM | #4 |
These are my favorite if they will work for you.
Link to d-ring: https://www.etrailer.com/Tie-Down-An...ophy/RR06.html
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
