Old 11-07-2022, 11:20 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
Double wall vs Single wall sun visors ??
Blazer is getting final touches at body shop and there are a few more pieces that I need to get color matched - one of those are he sun visor brackets
I have the factory DOUBLE WALL top sun visor brackets BUT just bought a really good SINGLE WALL top
Question - are the sun visor brackets the same between the single wall and double wall ???
thanks
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 11-07-2022, 03:52 PM   #2
Thealien
Thealien's Avatar
Re: Double wall vs Single wall sun visors ??
Sorry I don’t have an answer for your question but I believe they’re the same.
I have been looking for a single wall for a long time myself. Just wondering if you don’t mind what it cost to get one?
Old 11-07-2022, 04:34 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Brackets are the same regardless of the top style. Good find on the single wall. Do your bed sides have OE caged nuts for the single wall top?
Old 11-09-2022, 01:12 PM   #4
6600DURAMAX
Fortunately for me, my top rails have both holes OR holes and capture nuts. I have heard this is true of some of the 72 model years.
This one cost me $1,800 not cheap and still needs some minor repairs on the front passenger corner. But there are no cracks and is in overall great shape. The hatch does need some repair at the top hinges.
My double wall isn't the worst one I've seen but does need a decent amount of repair to be perfect.
Does anyone know if the single wall and double wall hatches are the same ?
Old 11-09-2022, 01:32 PM   #5
6600DURAMAX
here are the top pics
Old 11-09-2022, 01:33 PM   #6
1rippen6
For the most part yes, I believe the hinge seal is different on the 2 but if you have to do repairs that can be modified.
1rippen6 is offline   Reply With Quote
Old 11-09-2022, 01:55 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The hatches and hinges are the same but the hatch hinge seals differ. The 1x walls have a plate backed by a gasket at the exterior hatch end. The 2x walls use a single rubber seals no metal plate. I used the 2x wall hatch hinge seals on the single wall top top I swapped onto my 72.
Added: Some 2x apparently made use of the plate/gasket too probably confined to 72 MY examples but we'd need to dig out some examples to confirm.
Old 11-09-2022, 02:08 PM   #8
6600DURAMAX
any pics by chance
Old 11-09-2022, 02:27 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
any pics by chance
See examples here: http://67-72chevytrucks.com/vboard/s...3&postcount=30
Another: https://bringatrailer.com/listing/19...let-blazer-10/ 2x wall with the seal no plate
Another: https://bringatrailer.com/listing/19...let-blazer-44/ 2x wall with the plate
I should clarify, I've only seen 1x wall tops FWIW that make use of the plate and gasket but some 2x wall examples also used this.
Old 11-09-2022, 04:03 PM   #10
6600DURAMAX
Thanks Deadhead, I understand what you are saying now..... glad you clarified I was imagining something totally different
Old 11-10-2022, 12:32 AM   #11
Tmend
Tmend's Avatar
Here is a single wall with the plates. Also every single wall I’ve seen or owned had them on the top as well not just the hatch
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 11-10-2022, 04:23 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That sure looks nice
