11-07-2022, 05:08 PM | #1 |
Brake fitting ?
Running my brake lines . Have a CPP dual MC with disc front drum rear . Running 3/16 lines and need to know what size the rear brake connection is on the proportioning valve so I can get a fitting to go from it to the 3/16 line ?(3/8 steel nut) Also need to hard line connect the rear wheel cylinders to the 3/16 line and need the correct adaptors. What is the wheel cylinder female fitting size?
11-07-2022, 08:17 PM | #2 |
Re: Brake fitting ?
All fittings should be nverted flare.
What's the part number of the kit. That might either register with someone who used that same kit or let one of us who are inclined to do a bit of research find info on it. It might or should be in the instruction sheet.
11-08-2022, 04:42 AM | #3 |
Re: Brake fitting ?
Called inline tube and got the info T Block: GMTEE02
Adapter for rear of prop valve: ADT2 Adapters for wheel cylinders: AD10 in case anyone runs up against this in the future |
