11-19-2022, 08:51 PM | #1 |
Transfer case bolt questions
Anyone have/offer the proper bolt kit for the rebuilding of a NP205? Would like to find correct bolts in yellow zinc.
Or if anyone knows of a good plating company that can actually yellow sink my originals I would appreciate the lead. |
11-19-2022, 10:18 PM | #2 |
Re: Transfer case bolt questions
The company I retired from has a plating plant and can do yellow zinc. It won't be cheap. They have a minimun charge that far exceeds the cost of the bolts.
Douglas Machine Metal Finishing. Alexandria MN. As an alternative most grade 8 bolts at the box stores are yellow in color. |
11-20-2022, 12:16 PM | #3 |
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-22-2022, 12:32 PM | #4 |
I would check to see what is available at a NAPA store. Their Grade 8 bolts have a Gold Zinc plating.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
