Old 11-23-2022, 12:44 PM   #1
Jcl8034
Carpet - Back Cab Wall Install??
Working to re-do the interior (72 K10), but need tips on installing the carpet on the back wall of the cab. Moved the tank from inside to under the bed, now need to cover the back wall.
I bought the backwall kit from ACC, so the carpet is already molded to fit.
Any tips on getting this to stay in place? Just use spray adhesive and glue it to the Kilmat stuff? Will that hold it in place over a long period of time in the hot Texas heat?
I searched the forum and on YouTube and could not find much help on this topic.
Jcl8034 is offline   Reply With Quote
Old 11-23-2022, 06:21 PM   #2
Johnl48
Re: Carpet - Back Cab Wall Install??
Apply contact cement to both surfaces. Allow to dry then carefully apply it. Get someone to help you
Old 11-23-2022, 11:13 PM   #3
Jcl8034
Thanks John, I hadn’t thought about trying contact cement. Was just thinking spray adhesive, but the other sounds better.
Old 11-24-2022, 10:09 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
It has been suggested by a couple of people on here to use vinyl top adhesive for a better bond. I think you can get it in a quart can or spray can.
LockDoc
Leon
Old 11-24-2022, 10:28 AM   #5
56 3100
56 3100's Avatar
if molded to fit 3M 77 Spray adhesive should work spray carpet and metal. i just did sub enclosure and used remaining carpet to do back. i used kilmat as well.
wall done
box covered
56 3100 is offline   Reply With Quote
Old 11-24-2022, 10:56 AM   #6
Jcl8034
Well, three different suggestions. Conclusion - use some good adhesive!
Old 11-24-2022, 11:48 AM   #7
56 3100
56 3100's Avatar
regular contact cement a lot of fumes . 3m not as bad if doing inside .
