Old 11-25-2022, 02:55 PM   #1
WarMonger
WarMonger's Avatar
Help with 1970 C10 drop spindles
I have a 1970 C10 with a disc brake conversion on the front. I wanted to do 2-1/2 drop spindles. Do you know of anyone that makes them? Here are pics of my set up.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-25-2022, 03:02 PM   #2
WarMonger
WarMonger's Avatar
Re: Help with 1970 C10 drop spindles
This is the disc brake conversion I believe is on the truck.
1970 C20
-_--_--_- ______
1972 K5
Old 11-25-2022, 03:55 PM   #3
Grumpy old man
Grumpy old man's Avatar
Buy CCP parts thru Summit for the fast free shipping , Moog ball joints / tie rods / etc from Rock auto . when installing the upper ball joints the nuts go on top to avoid grease cup damage .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 11-25-2022, 04:19 PM   #4
WarMonger
WarMonger's Avatar
That set-up looks great. Thanks for the info.
1970 C20
-_--_--_- ______
1972 K5
Old 11-25-2022, 04:31 PM   #5
Jason Banks
Jason Banks's Avatar
Keep in mind CPP makes 2 types of spindles. They make they style grumpy pictures and their 'modular' type which are adaptable to many different caliper types with changeable brackets. You could get the brackets to fit the stock calipers it appears your kit uses and if you ever wanted to upgrade further, you could get different brackets.
Jason Banks is offline   Reply With Quote
Old 11-25-2022, 04:33 PM   #6
WarMonger
WarMonger's Avatar
that is rad. thanks for the info
1970 C20
-_--_--_- ______
1972 K5
