Old 11-26-2022, 12:11 AM   #1
riz
5.3 and 6.0 part compatibility ?
I currently have a 6.0 LQ4 being built and will not be using quite a bit of the stock parts from it........ I also just picked up a 5.3 LM7 and wanted to know if I could use the stock 6.0 parts on the 5.3 ??
Items from the 6.0 I'm wondering if I can use on the 5.3 are the following:
intake - both engines have cathedral port heads
camshaft
water pump
brackets
front cover
etc....
Any info would be appreciated....like if they would work, what other things would need to be done to make them work or if they swap with no extra work or parts.
Thanks in advance.
RIZ
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 11-26-2022, 02:32 PM   #2
Joyridin
Re: 5.3 and 6.0 part compatibility ?
They are both Gen 3 engines, so pretty much everything should fit. The only issue on the water pump and brackets might be what the engines came out of. There were different offsets for various cars/truck applications.
The front cover, camshaft, intake should all interchange.
Joyridin is offline   Reply With Quote
Old 11-26-2022, 06:10 PM   #3
LS short box
I don't think you will have a problem but really take real close look at the cam shaft. Even though it's a roller cam but if it's got some weird wear patterns on the lobes I would not reuse it.
LS short box is offline   Reply With Quote
Old 12-03-2022, 10:35 AM   #4
cj847
cj847's Avatar
If you want a little extra performance, you can use the LM7 heads on the 6.0. It will bump the compression up a little.
cj847 is offline   Reply With Quote
Old 12-04-2022, 12:34 PM   #5
riz
what would the 317 LQ4 heads do to the LM7?
RIZ
81 C10 short box
82 K5 Blazer
Old 12-05-2022, 08:25 AM   #6
71cadc10
71cadc10's Avatar
it will drop the compression of the 5.3
changing from ~64cc to 72cc chambers.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 12-05-2022, 01:07 PM   #7
riz
Could I put the stock LQ4 6.0 cam into the LM7 5.3 to pump up the 5.3? If so, would I need to do anything else or would I just swap cams? What would the increases be on the 5.3 ?
RIZ
RIZ
81 C10 short box
82 K5 Blazer
Old 12-05-2022, 10:33 PM   #8
LS short box
My .02 no gains worth talking about.
