11-27-2022, 09:29 PM | #1 |
71 K10 auto shift linkage bushing
Does anyone have a source for the plastic bushing where the shift rod attaches to the trans linkage… at the bottom end of the rod where the wire clip/cotter pin is?
All I seem to be able to find is the whole kit with a bunch of parts I don’t need. Thanks |
11-28-2022, 02:11 PM | #2 |
Re: 71 K10 auto shift linkage bushing
Would need more info, and to compare what original looks like.
https://www.summitracing.com/search/...word=RNB-02373 |
11-28-2022, 07:34 PM | #3 |
That’s the one at the top on the column. Can’t seem to find the bottom one at the transmission. I’ll check the trusty ol help section at Napa.
11-28-2022, 07:39 PM | #4 |
Like to know too
11-28-2022, 07:40 PM | #5 |
Here are some images from the parts catalog. I'm assuming you're looking for item #6. I believe the GM part number for that bushing/grommet is 3833107. A quick google search for that part number brings up this result.
https://shiftworks.com/products/univ...inkage-grommet I believe item #20 is the grommet that goes in the arm that sticks out of the bottom of the steering column, and it appears to be part number 3975131. |
11-28-2022, 07:52 PM | #6 | |
11-28-2022, 09:37 PM | #7 |
Thanks PJ. Amazing what having a part number will do. Much appreciated.
