11-27-2022, 09:54 PM | #1 |
New Rear Drums - Help with what size to order
Just about to pull the trigger on a set of drums from Rock Auto and am worried about getting the right size.
The ones I have chosen say 11x2", the other options don't say a size. I have the base model truck with a 5 bolt wheel and a 12 bolt rear end. I've just removed a rear tire and measured across the front of the drum and I get about 11.75 inches. The drum depth is almost 4 inches. Is this the right size to order? Or is the stock size the drums with no measurements in the listing?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
11-27-2022, 09:56 PM | #2 |
At the body shop.
Re: New Rear Drums - Help with what size to order
The brake shoe width
" That didnt make it any newer " " Dont antique the equipment " |
11-27-2022, 10:27 PM | #3 |
So would 11x2" inch be the right size for my setup?
11-27-2022, 10:42 PM | #4 |
Who Changed This?
Is it possible for you to take a brake drum to a local store and tell them what you have, along with the drum? Maybe take both drums and the shoes along so that they can figure out what you have?
11-27-2022, 11:39 PM | #5 |
If you take a drum off measure across the shoes and the width of the shoe or you can measure inside the drum the diameter and the depth where the shoe has been riding. I hope this helps.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-28-2022, 01:17 AM | #6 |
NAPA shows one drum for a 1971 Chevy C10 so I wonder if there's an issue.
11-28-2022, 01:53 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
The 71 and 72 C/10's with the 12-bolt axle have 11" drums with 2" shoes...5x5 lug pattern.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-28-2022, 01:57 AM | #8 |
I only think they used 11x2 on both C10 5 lug and K10 6 lug . I don't remember other sizes used that year.
11-28-2022, 01:58 AM | #9 |
Yes, as long as the factory 12-bolt axle is still there, you should be good to go with 11" drums with five lug holes. The brake shoes are 2" wide.
11-28-2022, 03:25 PM | #10 |
Awesome, thank you gentlemen for all your help!! Yup 12 bolt is still there, 5 lug tires Ill order those up!
11-28-2022, 03:55 PM | #11 |
Post Whore
Personally I would measure them. I have swapped numerous rear brake set ups over the years to improve braking. Your truck is 50 years old and things may have been swapped somewhere along the line.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-28-2022, 03:58 PM | #12 |
might want to order new wheel cylinders also...or rebuild kit and hone yours. IMHO they are fairly cheap so just get new ones. I also got my 72, 5 lug rear brakes from RA
If the center soft line is old, replace it also |
11-28-2022, 05:27 PM | #13 |
Oh yeah for sure, I'm doing the full brakes, wheel cylinders and center brake line. Everything in the front too, calipers, disks etc. 50 years, time for some new stuff
