Old 12-23-2022, 05:01 PM   #1
307Niner
Cruise control
I have a Gen 2 LT-1, and I’m doing wiring right now. It will run on a 0411 pcm from a LS pickup. I want to add cruise control while I’m already working the harness. Looks like it’s a simple deal from searching around here. Two questions…
Where have you mounted your cruise control modules? Anybody hidden one?
Is there any option for a switch on the column, like ls1nova previously made? He hasn’t responded to PM.
Pickup is a 68 C10 short bed. Thanks for any help.
307Niner is offline   Reply With Quote
Old 12-26-2022, 08:31 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Cruise control
Here is a write up ls1nova done on cruise control using a gm drive by cable module. All info in there should work with your setup.
As for hiding the module, I think a hole in the firewall and a grommet to run the cable out and you could hide it under the dash. And it will be a lot easier to hide the wiring that way as well.
https://67-72chevytrucks.com/vboard/...ontrol+ls1nova
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
