Old 01-02-2023, 03:31 PM   #1
72SB
3 OTT and 3:08 gears
Anyone running this set up?
If so is "feathering" (slipping) the clutch required in first?
Looking to reduce FWY RPM's
Current gears, 3:73, 12 bolt truck
My understanding I need to switch to a 2 series carrier to go higher gear ratio other than 3:73
72SB is offline   Reply With Quote
Old 01-02-2023, 03:54 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 3 OTT and 3:08 gears
Tire size has a big impact on the rpms. what tire size you running?
What engine and how do you use your truck?
Old 01-02-2023, 03:54 PM   #3
jimijam00
If you got torque, you need not worry about having to "feather" the clutch.
jimijam00 is offline   Reply With Quote
Old 01-02-2023, 04:38 PM   #4
72SB
Have a 250 6 cyl
Yes aware tire size affects RPM. Current 235/75 x 15's BFG's
with the 2.85 1st, was asking if anyone is using a 3:08 rear gear with 3 OTT
I drive Fwy often so would like to run at 70mph vs 55 mph and be under 3k rpm.
Using RPM calculator, the 3:08's do that
Old 01-02-2023, 04:49 PM   #5
Warrens69GMC
I have a 1978 c10 with 350 /th350 and 3.08. It does do well, but you need more torque from the 250 to get there IMO. Consider a 3 speed with overdrive instead of a new rear end/gear change.
Old 01-02-2023, 07:27 PM   #6
jumpsoffrock
Honestly I think you're gonna be just fine, don't switch trans, don't add OD, just slip the clutch a bit.
As long as you really do mostly hwy driving.
jumpsoffrock is offline   Reply With Quote
Old 01-02-2023, 07:46 PM   #7
72SB
My 67 Camaro TH350 has 2.52 1st gear and I have 3:08 in that car. Yeah it makes over 400hp and TQ....so it will just boil the tires
Given the Saginaw 2:85 1st gear I suspect the 3:08 will be "normal" clutch engagement although I suspect won't just go off idle releasing the clutch now as it does with 3:73's
Completely aware of other trans swap possibilities, just asking if anyone has 3OTT and 3:08's and what initial clutch release is (read does it require feathering or slipping)
Old 01-02-2023, 10:04 PM   #8
tutone
tutone's Avatar
I ran that exact setup in a 68 back in the 80s. With the 250, you had to feather a bit but that engine was tired. I replaced it with a healthy stock 1972 350 and it lasted for years. I think you will be fine.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 01-02-2023, 10:22 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Agreed. I had a '69 Camaro (admittedly, it had a 327) with a close-ratio Muncie (2.20:1 low) and a 3.08 axle. It worked just fine; got good mileage when I kept my leg out of it and had a crazy top end.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-03-2023, 07:43 AM   #10
68panelman
68panelman's Avatar
Subbing on this
68panelman is offline   Reply With Quote
Old 01-03-2023, 07:55 AM   #11
My 70 is a 3OTT with 3:08 rear. Granted I have a 350, but no issues driving normal. IF you are going to pull or haul heavy loads you then may be slipping clutch to get it rolling. My last truck was a 250 6 with 2.73 rear gears and no issues with it either. Just no low end umph, but drives just fine.
Old 01-03-2023, 08:03 AM   #12
A1971Blazer
A1971Blazer's Avatar
My Dad bought a new truck way back in 79....350 3OTT.....3.08
not a lot of clutch slipping normally...... but a lot trying to pull his boat up the ramp...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-03-2023, 08:54 AM   #13
I don't have this combination. But I can't imagine not being hard on the clutch. I tried a 3.08 rear with a Muncie 4spd and felt that was too high pulling out. Went with 3.42s for a happy medium. I started off with 3.73s and was looking for better cruising gear. The thing I never liked about the 3spd is tall gearing down low. Not just off the line in 1st, but taking slow turns in 2nd gear too.
Old 01-04-2023, 12:01 AM   #14
jumpsoffrock
Man a new clutch every 50-80k miles sounds cheaper than a full trans swap or even a basic rear gear change if done by a shop.I know it wouldn't cost an arm-and-a-leg for a gear change but that's not what this thread is about.
It sounds like a few people have managed with the setup the OP is asking about.
Old 01-04-2023, 09:29 AM   #15
I do my own work. There's more to it than cost anyway. It's drivability. That was the question. I was giving my impression of the combination asked about by referring to another combination that should work better, having a lower first gear and closer ratios throughout (also a 325hp 350). I've had 6cyl/3spd trucks with 3.73 and couldn't imagine running 3.08s. I guess GM agreed. I never knew of anyone running that combination until this thread. Different people get different impressions. Mine is no thanks.
Old 01-04-2023, 06:07 PM   #16
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Did the exact swap you are asking about. Yes on the 2 series carrier, and you will be Good to Go. I run 275/60/15's on mine and it runs fine. Original 250 6cyl, 3 OTT , 3.73 rear, Now 283, 3OTT, 3.07's or 8's depending on the day...Clutch works fine. Now go to a 2.76 and the truck will not pull itself over a curb without straining....(Been there, done that)....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 01-04-2023, 06:29 PM   #17
72SB
^^, thanks for the comments on your set up
The 2 series Yukon though is the biggest cost. Its a peg leg now. This truck may see a V8 swap at some point but for now the 250 six runs fine so will get to the gear/carrier swap. My 30 spline axles will work with the Yukon diff
https://www.summitracing.com/parts/y...ckup/year/1972
Gears:
https://www.summitracing.com/parts/m...-308?rrec=true
Bearing Kit:
https://www.summitracing.com/parts/m...rmkt?rrec=true
Old 01-04-2023, 07:22 PM   #18
jimijam00
I'd go drive a truck with the exact setup I was considering before I spent a bunch of money and time on modifying the rear end.
Old 01-04-2023, 08:38 PM   #19
71meangreenc10
Gears:
Bearing Kit:
Mine is a Open Carrier, I don't mind the Single Wheel Solo. It is a good cruiser that way for me. I changed everything and moved the engine to the V8 position when the 283 went in. I don't pull anything with it anymore so I am not worried about clutch slippage. I got enough trucks to do truck stuff. My C30's are going to be some great builds.
Smitty
71 C30 Wrecker
Old 01-04-2023, 10:07 PM   #20
HO455
Post Whore
HO455's Avatar
This may be a cheaper option for you. Not my transmission. Just offering an alternative.
https://seattle.craigslist.org/sno/p...565561671.html
RIP Bob Parks.
