01-05-2023, 03:48 PM | #1 |
Junior Member
Drip rails
Does anyone know of a vendor that sells door drip rails with the correct height of the outer flange? All I've found are 1/8" short. I did a search on the forum and found an older thread that said all were made by one manufacturer and all were wrong.
01-06-2023, 06:55 AM | #2 |
Re: Drip rails
Nothings changed, still just 1 manufacturer and made incorrectly.
Paul Jr @ GMCPauls |
01-06-2023, 09:45 AM | #3 |
Junior Member
Re: Drip rails
Thanks for the reply, at least now I can stop looking and figure out a plan.
01-06-2023, 06:03 PM | #4 |
Re: Drip rails
On my 68 it had a couple bad spots in the vertical part of the drip rails. I cut out the bad vertical spots. Then I got some 1/8"? flat stock from the hardware. Cut it to length and welded it into place. I had to grind the top of the flat stock to match the stock drip rail height. Once done you could not tell.
