01-07-2023, 12:22 PM | #1 |
Restoring it $200 at a time...
68 window guts in a 72 door
The basic project:
1. Since I'm using the 68 interior panel, I don't need to worry about the longer shaft on a 72 window regulator, correct? 2. Should I try to use the 72 reinforcing screw with a 68 vent window, or just weld up the hole and be done? Thanks
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
01-07-2023, 12:47 PM | #2 |
Its a Truck Thing......
Re: 68 window guts in a 72 door
The 68 guts will move over, just have to figure out the 4 bottom screws fastening the panel to the 72 door.
Second issue is to your taste. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-07-2023, 03:24 PM | #3 |
#1- If using 67-71 door panel you need to use 67-71 door relay and window regulator. The only time 72 door relay & window regulator are used is with the 72 door panel as it sticks out further from the door requiring the longer shaft.
#2- The 72 reinforcing screw was made because GM found out over time the metal strap under vent window was prone to separate or break resulting in the opening spreading wider at the bottom of the door glass by leaving it you'll be able to prevent this occurring but you also won't match passenger side. So you eliminate a issue by leaving but affect the visual aesthetic of both doors matching in appearance. Paul Jr @ GMCPauls |
01-09-2023, 01:36 PM | #4 |
Good deal. Thanks guys
01-09-2023, 02:41 PM | #5 | |
Not many other sellers take the time to do that....I'm sure that I'm not the only one who appreciates it...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
